Changed the PSU to something better.
case is personal but i picked the Phantom since its good looking
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($219.98 @ OutletPC)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($26.75 @ OutletPC)
Motherboard: MSI Z97S SLI Plus ATX LGA1150 Motherboard  ($90.50 @ Newegg)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory  ($66.99 @ Newegg)
Storage: Kingston SSDNow V300 Series 120GB 2.5" Solid State Drive  ($54.99 @ SuperBiiz)
Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card  ($348.99 @ Directron)
Case: NZXT Phantom 410 (White) ATX Mid Tower Case  ($59.99 @ Newegg)
Power Supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($69.99 @ NCIX US)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($18.75 @ OutletPC)
Total: $956.93
if you could pay an extra $10 to get the Crucial SSD it would be much better
Storage: Crucial MX100 256GB 2.5" Solid State Drive  ($108.99 @ SuperBiiz)
Total: $1010.93
Generated by PCPartPicker 2014-12-17 20:52 EST-0500
My PC
[ I5 4690k (no oc) - Gigabyte Z97 D3H - 8GB Ram - Sapphire R9 280X Vapor-X ]
https://linustechtips.com/topic/272225-recommend-me-a-mobo-case/#findComment-3693148
You might want to avoid that SSD. I think it's gotten a bit of a bad rep and seems to have very rapid performance degradation.
I would recommend going with a UD3H-BK or a Z97-A.
I can't recommend you a case because I don't know what's visually appealing to you, so spend the rest of that on the case by using PCPP sort by price and limiting it to the remainder of your budget after selecting a board.
You should probably decide on these things by yourself since they're fairly important, rather than taking the suggestion of "some guy on the internet"
https://linustechtips.com/topic/272225-recommend-me-a-mobo-case/#findComment-3693153
change PSU With Better PSU
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($179.99 @ Micro Center)
Motherboard: EVGA Z97 FTW ATX LGA1150 Motherboard  ($140.98 @ Newegg)
Total: $967.42
Generated by PCPartPicker 2014-12-17 20:55 EST-0500
Current Build + Setup
AMD Ryzen 7 5700X | GIGABYTE B550 Aorus Pro v2 | CORSAIR Dominator Platinum 16gb 3600Mhz | GIGABYTE RTX 3070 AORUS MASTER OC 8 GB | NZXT H510 Elite | 2TB Seagate Barracuda 7200RPM | ADATA XPG GAMMIX S7 512GB M.2-2280 NVME | Corsair RM850 80+ Gold Modular PSU | NZXT Kraken X63 | Harman Kardon Soundstick 4 | Koorui 27E1Q
https://linustechtips.com/topic/272225-recommend-me-a-mobo-case/#findComment-3693169
My Build: http://pcpartpicker.com/p/jdt6P6
Also feel free to suggest parts :)
My 1st Build so take it easy :)
Budget: No more than $1000 (Not including monitor, keyboards, mouse, etc.)
it was pretty good...suggested motherboard support SLI and i swaped the SSD for something much better that won't cost much more...
The build is entirely color coordinated and also i picked ram that will actualy fit with the big tower heatsink ;)
Also i picked a much better powersupply for you...the corsair CX are lame.
Motherboard: MSI Z97-G45 Gaming ATX LGA1150 Motherboard  ($119.99 @ Micro Center)
Memory: A-Data XPG V1.0 8GB (2 x 4GB) DDR3-1600 Memory  ($59.99 @ Newegg)
Storage: A-Data Premier Pro SP600 128GB 2.5" Solid State Drive  ($60.98 @ Newegg)
Case: Enermax ECA3280A-BR ATX Mid Tower Case  ($69.99 @ Amazon)
Power Supply: Antec High Current Gamer 620W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($63.98 @ Newegg)
Total: $989.40
Generated by PCPartPicker 2014-12-17 20:57 EST-0500
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/272225-recommend-me-a-mobo-case/#findComment-3693171
This is what I'd do. You don't need an optical drive in this day an age. You can install your OS with a flash drive.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($219.99 @ Amazon)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($30.99 @ SuperBiiz)
Motherboard: MSI Z97S SLI Plus ATX LGA1150 Motherboard  ($110.49 @ Amazon)
Storage: Crucial MX100 128GB 2.5" Solid State Drive  ($62.99 @ Amazon)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($65.99 @ SuperBiiz)
Power Supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($76.99 @ SuperBiiz)
Total: $983.42
Generated by PCPartPicker 2014-12-17 21:01 EST-0500
https://linustechtips.com/topic/272225-recommend-me-a-mobo-case/#findComment-3693215
