So basicely I've decided that I want to build a new gaming pc. Unlike my old PC I figured that I want to watercool the processor with a pre filled water cooler (like the corsair H(i) series or something).
But I have a few questions that I'll be thankfull for if they get answered.
1. What type of watercooling should I buy? You have the H(i) series from corsair but also a lot of watercoolers from cooler master . And is a radiator like the corsair h80I enough or does it really get a lot cooler using something like a H100?
2.There's one more thing im worried about: where should I install the radiator? If I put it in front wouldn't heat the HDD'S? And if I put it above sucking air in wouldnt it mess up the airflow?
Sincerely
https://linustechtips.com/topic/271308-need-help-with-watercooling/
I  would get a corsair h110 witch is a 280mm rad and i would mount it in the front so the cpu gets fresh air
Buy my yoga 2 pro!  http://linustechtips.com/main/classifieds/item/2711-lenovo-yoga-2-pro-i7-4510u-8gb-ram-4k-btc-accepted/
[spoiler=Trumps Wall
]AMD FX 8320 OC@ 4.4 GHZ GPUamd sapphire 7950RAM: 12GB CORSAIR XMS3 Psu: Corsair cx 500m CASE: Corsair 800d MOBO: Asrock 970 extreme 3 r2 Storage: 256GB mx100 SSD, 1TB WD Blue,1tb Seagate Barracuda in Raid 0, 750GB Seagate Baracude. Os Windows 7
CPU: AMD A-10 5800k RAM: 4GB DDR3 Storage:Random drives Mobo:msi SomthingCase: good question
What case do you have?
Something like the H105 is a good cooler and will do well with any CPU. The H80i is good, but I'd recommend a 240mm rad or more for better temps when overclocking.
Most of the time it's best to have the radiator in the top, exhausting air out of the case. That way, you're not bringing hot air into the case.
1) the bigger the better. Sizing performance goes like this:
120mm<140mm<240mm (2x120)<280mm (2x140)<360mm (3x120)
You should choose the biggest size that fits in the case you are getting.
2) I would need to know what case it is, so that I can tell you which size fits where.
Wouldnt the air be hot from other components?
Also I'm problaby getting a case like the 450D, But if you have Better suggestions please tell me
What case do you recommend?
What budget do you have?
How big do you want it to be?
What kind of colour/looks do you like?
About 100 euros (about 125 dollars)
I'm problaby putting a Sapphire R9 290x in there, and that card is huge (305mm)
For storage an SSD and 1 or 2 HDD'S
And ofcourse an atx motherboard
The colours I like are mostly black
Take a look at corsair, phanteks, and NZXT cases, they are pretty good.
Thank you! :D
you're welcome :)
I'd recommend a Vengeance C70 for a case but I'm biased on that as I have one,lol (running two 240 rads with alot of room in the case still)
But the H105/110i should work well if not the Swiftech H220x
Project Gray Scale
Intel Core i7 6900k @ 4.2Ghz - Dominator 32GB DDR4 2400 CL10 - Samsung 970 EVO+ 1TB NVMe - 2 Samsung 840 EVO 1TB (Gaming and Sratch) - 2 Barracuda 2TB
Asus x99 Deluxe - MSI Aero OC GTX 1080Ti - Seasonic 760 XP² - Mod1PC Custom Cables - EKWB CPU & GPU Blocks Nickle/Plexi - EKWB D5 PWM
EKWB PE360 - Corsair ML120 (6)  - InWin 303- NK65 Entry Watermelon w/ Gat Laseron 70g (205g0 & Filmed) - Logitech G Pro x Superlight
Kanto YU2 - Sennheiser PC360 SE - Acer XF270HU
BUT DOES IT FOLD?! https://folding.extremeoverclocking.com/user_summary.php?s=&u=963814
Get the Nepton 280L if your case is big enough. It's a massive radiator that performs on par with H110, and in my country it's about €50 cheaper. It has a bit of a strange tube design that some may not like, but if you're that hell bent on minor aesthetics, then whatever.
| CPU: Intel i7 4790K @4.4Ghz  | GPU: Gigabyte GTX 970 G1 Gaming  | CPU COOLING: FRACTAL DESIGN S36 | MOBO: ASUS ROG Maximus Vii HERO | RAM: 16GB G.Skill Ripjaws X @1600MHz  | CASE: Phanteks Enthoo Pro Full Tower | PSU: EVGA SuperNova 850 G2 850W Fully Modular | HDD: 2TB Seagate Barracuda | SSD: 256GB Crucial MX100 | DISPLAY: Dell U2414H | HEADSET: Corsair H2100 Dolby 7.1 Surround |
Your case info would be nice.
Case:Define R4 | MOBO:ASRock z75 Pro 3 | CPU:i7-3770k 4.0GHz | CPU Cooler:H100i | GPU:970 Strix | RAM:Hyper X 16GB |
Peripherals:ATH-M50x Limited Blue Edition | K95 RGB | M65 RGB | Blue Yeti MIC | (3x)1920x2080 Acer Monitors
