Hey! I'm new to computer building, and i'd just liek to know if my build is enough. I am an average gamer and play lost of games, but i am not too sure if my pc is good enough. I've been struggling with my cpu, and gpu because i don't know what is good for a 700$ rig.
Any suggestions will be appreciated!! :)
Thank You
Build - http://pcpartpicker.com/p/LFWHrH
https://linustechtips.com/topic/271013-help-pc-build/
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($172.94 @ SuperBiiz)
Motherboard: *ECS H81H3-A3 ATX LGA1150 Motherboard  ($42.98 @ Newegg)
Memory: *Team Elite Plus 8GB (1 x 8GB) DDR3-1333 Memory  ($54.99 @ Newegg)
Storage: *PNY Optima 240GB 2.5" Solid State Drive  ($80.98 @ Newegg)
Video Card: *XFX Radeon R9 285 2GB Double Dissipation Video Card  ($185.99 @ NCIX US)
Case: Corsair SPEC-02 ATX Mid Tower Case  ($69.98 @ OutletPC)
Total: $703.24
Generated by PCPartPicker 2014-12-15 20:41 EST-0500
FANBOY OF: PowerColor, be quiet!, Transcend, G.Skill, Phanteks
FORMERLY FANBOY OF: A-Data, Corsair, Nvidia
DEVELOPING FANBOY OF: AMD (GPUS), Intel (CPUs), ASRock
https://linustechtips.com/topic/271013-help-pc-build/#findComment-3676998
over 36 $ but worth it
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  ($44.99 @ Directron)
Memory: A-Data XPG V1.0 8GB (2 x 4GB) DDR3-1600 Memory  ($59.99 @ Newegg)
Video Card: Zotac GeForce GTX 970 4GB Video Card  ($324.99 @ NCIX US)
Case: Thermaltake VL80001W2Z ATX Mid Tower Case  ($24.99 @ Micro Center)
Total: $736.79
Generated by PCPartPicker 2014-12-15 20:45 EST-0500
Current Build + Setup
AMD Ryzen 7 5700X | GIGABYTE B550 Aorus Pro v2 | CORSAIR Dominator Platinum 16gb 3600Mhz | GIGABYTE RTX 3070 AORUS MASTER OC 8 GB | NZXT H510 Elite | 2TB Seagate Barracuda 7200RPM | ADATA XPG GAMMIX S7 512GB M.2-2280 NVME | Corsair RM850 80+ Gold Modular PSU | NZXT Kraken X63 | Harman Kardon Soundstick 4 | Koorui 27E1Q
https://linustechtips.com/topic/271013-help-pc-build/#findComment-3677023
i3
Total: $696.79
Generated by PCPartPicker 2014-12-15 20:46 EST-0500
https://linustechtips.com/topic/271013-help-pc-build/#findComment-3677050
I do, but i can do that seperately, if you'd like i'll spen max 80$ on headphones, and g710+ keyboard probably, and idk any mouse ideas?
include in this budget or not in budget ?
https://linustechtips.com/topic/271013-help-pc-build/#findComment-3677057
@Newbie312:
This is pretty well balanced:
CPU: AMD FX-8320 3.5GHz 8-Core Processor  ($139.99 @ Newegg)
Motherboard: Gigabyte GA-970A-UD3P ATX AM3+ Motherboard  ($89.99 @ Newegg)
Storage: Kingston Fury 120GB 2.5" Solid State Drive  ($59.99 @ Amazon)
Video Card: XFX Radeon R9 280 3GB Double Dissipation Video Card  ($185.99 @ NCIX US)
Case: Corsair SPEC-03 Red ATX Mid Tower Case  ($44.99 @ Newegg)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply  ($44.99 @ NCIX US)
Case Fan: BitFenix Spectre 43.5 CFM 120mm  Fan  ($8.98 @ OutletPC)
Total: $695.14
Generated by PCPartPicker 2014-12-15 20:47 EST-0500
Aesthetics of rigs matter
42
If you're interested, participate in LTT Build Offs
https://linustechtips.com/topic/271013-help-pc-build/#findComment-3677062
Total: $703.24
Tad better http://pcpartpicker.com/p/CBdB4D
@Newbie312:
Total: $695.14
Um, NOPE http://pcpartpicker.com/p/CBdB4D
https://linustechtips.com/topic/271013-help-pc-build/#findComment-3677170
 Wrong section. Also, you can do A LOT better for the price
How about an i5 and an r9 290 ?
Besides the ugly mobo, that would destroy for sub $700! Though Windows (unless steamOS is still a thing) should always be considered since it's another $100 :P.
PCPartPicker Link To My Build
My YouTube channel, also check out my Twitch Stream!
Check out my Lastest CS:GO Video!
https://linustechtips.com/topic/271013-help-pc-build/#findComment-3677413
