Ok so I'm looking for a case that has a side pannel and can fit an atx or eatx board with a h100i in pp config on the top of the case. I have no idea if a case like this exists but if there is one that would be awesome. The only thing I could think of that would remotely fit this would be the antec 1900 and thats not even out yet.
https://linustechtips.com/topic/27042-case-questions/
800d, 900d, *cough* caselabs *cough*, A lot if not most cases support that :D what is your budget?
i5 3570 | MSI GD-65 Gaming | OCZ Vertex 60gb ssd | WD Green 1TB HDD | NZXT Phantom | TP-Link Wifi card | H100 | 5850
“I snort instant coffee because it’s easier on my nose than cocaine"
https://linustechtips.com/topic/27042-case-questions/#findComment-343221
You could go for the Coolermaster Scout, it has a window and the radiator fits in it.
But if you can tell me your price range that would be nice, than I can search for you.
Price range is about $200 maybe $300
https://linustechtips.com/topic/27042-case-questions/#findComment-343230
K then forget caselabs. Umm Check this http://linustechtips.com/main/topic/1523-h100-compatibility-thread/
https://linustechtips.com/topic/27042-case-questions/#findComment-343247
Oh ok yah thank you so much! I was looking at one on overclock.net but it was pretty outdated so its nice to know we have one. Thank you!
https://linustechtips.com/topic/27042-case-questions/#findComment-343250
Yup, it was kinda hard to find so it might be a little older to but it wont be that bad :D
https://linustechtips.com/topic/27042-case-questions/#findComment-343256
Yah ok cool cause the one on overclock looks like it hasn't been updated in at least a year.
https://linustechtips.com/topic/27042-case-questions/#findComment-343261
Corsair 600T, Corsair 650D, Corsair C70, all those will fit.
NXZT Phantom, Switch 810 so many more :P
Come and join the awesome Official LTT Star Citizen Org at LTT Conglomerat,  GTA 5 LTT Crew at LTT Conglomarate
PC Specs - 4770k - OC 4.5GHz  - GTX 780 SC - 16GB HyperX - NZXT H440 White - Corsair H100i - Corsair AX750 - Samsung Evo 250GB - 2 x PA238Q - ATH-M50 -
https://linustechtips.com/topic/27042-case-questions/#findComment-343321
