Help choosing effective budget Case.
My Build:
Intel core I5 4570
Asus H81m-A
Zotac GTX 970
G.SKILL Ripjaws 8GB (2 x 4GB)
Seasonic M12ii 520w
Crucial MX100 128gb SSD
Seagate Barracuda 1TB
My eyes are on this two;  COUGAR Spike and NZXT Source 210, will this cases fit my build? would it suffice?
Any Better choices?
Budget: 50$ below
https://linustechtips.com/topic/270078-help-choosing-effective-budget-case/
Is it a monkey? Is it an ape? I don't care, I LOVE'EM!
the cooler master n400 is 54.99 its a little over but its still a good case i plan on getting one for my one build http://www.microcenter.com/product/416980/N400_Mid_Tower_Computer_Case
My system is the Dell Inspiron 15 5559 Microsoft Signature Edition
                         The Austrailian king of LTT said that I'm awesome and a funny guy. the greatest psu list known to man DDR3 ram guide
        i got 477 posts in my first 30 days on LinusTechTips.com
N400, or the best, s340
My Build:
Intel core I5 4570
Asus H81m-A
Zotac GTX 970
Seasonic M12ii 520w
Any Better choices?
Budget: 50$ below
Your system is pretty damn power efficient so I wouldn't sweat going overkill on the cooling. A Source 210 with an extra 120mm fan or two (it comes with neither front intake nor top exhaust fans) will be more than enough. You might also consider the Rosewill Challenger as long as your video card will fit in it. Not too bad a deal for $45 and coming with three case fans.
Spike and Source 210 are both great cases. The Spike looks a bit nicer, but has no top fan mounts, and is only mATX.
Desktop: Intel Core i5 2380P (2400 w/o iGPU), MSI H61, 8GB RAM, 256GB SP610, 500GB WD Blue, HIS R9 280, Antec TruePower Classic 550W, Inwin MANA 134, QNIX QX2710, CM QuickFire Rapid, Logitech G402
Laptop: Toshiba Satellite L40D, AMD A6-6310, 6GB RAM, 500GB HDD, Radeon R4 Graphics, 14" 1366x768
Phone: iPhone 6 Space Gray 64GB, T-Mobile $60/mo 3GB plan
