Currently I installed a second 7970 and it worked fine. But the top GPU gets very hot 78c on unigine heaven benchmark. How can I make my bottom GPU to become the primary GPU? The bottom one has much better airflow (120 mm blowing on it). I tried switching over the monitor cables but it would not display anything on it.
[CPU] i7 4790K OC [CPU Cooler] H100i [GPU] Evga GTX 980 SuperClocked [Ram] Corsair Vengeance 16 GB 1866 mhz [PSU] Cooler Master 1000w Silent Pro [storage] 256 GB Samsung 840 Pro, 1TB Seagate SSHD, 1 TB WD Blue 4 TB Seagate Nas. [Motherboard] Msi Z97 Gaming 5 [Case] Phantom 410 Red [sound] Onboard ALC 1150 [Headphones] Sennheiser HD 558 [Keyboard] Razer BlackWidow Chroma  [Mouse] Razer Deathadder Chroma [Mouse] Razer FireFly [Monitor] Asus MG278Q
https://linustechtips.com/topic/269680-crossfire-help/
The top one is ALWAYS the primary one. Also 78C is not very hot at all
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/269680-crossfire-help/#findComment-3660809
During the run the GPU peaked at around 82c
https://linustechtips.com/topic/269680-crossfire-help/#findComment-3660853
How's your airflow in your case?
That plays a major part on keeping the cards cool.
Intel Core I7 7820X | Asus Rampage VI | Gigabyte RX 580 XTR | 32GB Crucial Ballistix | NZXT Kraken X62
ADATA XPG 256GB PCIe| Cosmos C700P CM | Lepa MaxPlatinum 1050W
https://linustechtips.com/topic/269680-crossfire-help/#findComment-3660916
I would say the air flow is decent. I have a front 140mm intake and bottom intake and side panel exhaust and back exhaust and a 240mm radiator at the top
https://linustechtips.com/topic/269680-crossfire-help/#findComment-3660992
