Hey guys so i just bought the k95 rgb and im pretty scared of having my keys and wrist pad turning oily. i know they sell the wrist pads separately but not the key-caps. i like keeping my things looking pristine. do you guys know anyway ways to clean them off or make them less shiny?
https://linustechtips.com/topic/269651-cleaning-peripherals/
Soft cloth with a bit of alcohol or water
https://linustechtips.com/topic/269651-cleaning-peripherals/#findComment-3660527
Thanks man
No problem ;)
https://linustechtips.com/topic/269651-cleaning-peripherals/#findComment-3660557
