Is buying an Intel Core i7-5960X worth it? or should i go with a normal i7? Cause i need an upgrade from my i5 and if i want an i7 extreme i need to buy a new mobo AND ddr4 ram, in total the upgrades are gonna cost me over 1500$, when i could just get an i7 for 300-500$. And if i choose a normal i7, which one should i go with?
https://linustechtips.com/topic/269600-i7-extreme/
What will you be doing? If you're just gaming, grab a 4790K, or 4690K.
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
https://linustechtips.com/topic/269600-i7-extreme/#findComment-3659827
Just buy a 4790k.
extreme edition is not worth it unless it is your job and you make money off it...
https://linustechtips.com/topic/269600-i7-extreme/#findComment-3659862
Thx a lot, im just gonna go with an i7 4770K because i do a lot of gaming but the huge upgrade to an extreme just isn't worth it.
If it's just for gaming, get something like i5-4690K. You can get that 4770k if you need more power, but don't get that 5960X and the rest of those upgrades as it'll cost too much
Follow the topics you create using the "Follow" button in the top right corner!
One day I will have my GTX 970. One day. PC specs are at my profile.
Not sure how to check what part works with what? Check out my compatibility guide!
https://linustechtips.com/topic/269600-i7-extreme/#findComment-3659963
Sounds great :)
Good choice.
https://linustechtips.com/topic/269600-i7-extreme/#findComment-3659965
Stick with your i5-4690k and upgrade to a Z97 board instead.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/269600-i7-extreme/#findComment-3660023
