everything looks compatible but get an i5 because the 8350 will bottleneck the gpu
My system is the Dell Inspiron 15 5559 Microsoft Signature Edition
                         The Austrailian king of LTT said that I'm awesome and a funny guy. the greatest psu list known to man DDR3 ram guide
        i got 477 posts in my first 30 days on LinusTechTips.com
it is pretty nice but the case IMHO is a bad choice...i'd look for something better in that price range, might want to look at the Enermax ostrog GT it comes with dual 140mm led fans for intake and a 120mm exaust fan pre-installed so you dont have to order a bunch of case fans for it and it has a side windows and just generaly MUCH better quality than this.
Available in red:
http://www.amazon.com/Enermax-Computer-Acrylic-See-Thru-ECA3280A-BR/dp/B00BKX75YA/ref=sr_1_1?ie=UTF8&qid=1418504824&sr=8-1&keywords=ostrog+GT&pebp=1418504823693
Or blue:
http://www.amazon.com/Enermax-Computer-Acrylic-See-Thru-ECA3280A-BL/dp/B00BKX760S/ref=sr_1_2?ie=UTF8&qid=1418504840&sr=8-2&keywords=ostrog+GT
My machine is built inside this case and i recommend it, it's nice.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
No OS?
Other than that yeah, those parts are fine.
Main Rig:-
Server:-
