Really not sure which section would be best for this. I was browsing youtube the other day when a file named f.txt automatically downloaded. From google searches I believe the file name is really f.txt.js . I deleted the file before I enabled show hidden extensions so I am not sure if this is the case. I scanned the file with kaspersky, and the computer with kaspersky, malwarebytes anti-malware free, and windows defender. Nothing showed up in any of these scans. Has anyone here had any similar experiences, it seems to have downloaded from a potentially malicious ad. Since then I have installed ad-block to prevent this from happening again, but I would like to remove it ASAP to continue supporting websites, youtubers, etc.
Athlon X4 760K | MSI A88X-G43 | 8GB G.Skill Ripjaws 1333Mhz | MSI R7 260X 2GB | Corsair 300R | Corsair CX430 | 640GB HDD | Windows 7 64-bit
HP W2071d 20" 900p TN | Stock Dell K/B | Microsoft Comfort Optical Mouse 3000 + SteelSeries Qck Portal 2 Ed. | Grado SR80i + cheap 2.0 speakers
https://linustechtips.com/topic/269532-ftxt-download/
This has never happened to me.
I have a setting 'Ask where to save each file before downloading' option, under Download location.
Do you have that (un)ticked?
https://linustechtips.com/topic/269532-ftxt-download/#findComment-3659079
After it downloaded I ticked the box, but it was previously unticked.
https://linustechtips.com/topic/269532-ftxt-download/#findComment-3659091
Its hardly from adsense or any other google ad. Were some other tabs open at same time?
Possibly, but I believe it was only youtube tabs.
https://linustechtips.com/topic/269532-ftxt-download/#findComment-3659094
Go to your chrome downloads (Chrome://downloads in your URL bar) and see what URL it was downloaded from (the server)
https://linustechtips.com/topic/269532-ftxt-download/#findComment-3659107
yeah... I cleared cache and everything. Not the best move.
https://linustechtips.com/topic/269532-ftxt-download/#findComment-3659131
You have any other programs you suggest running?
https://linustechtips.com/topic/269532-ftxt-download/#findComment-3659133
Well, no way you're gonna know where you got it from unless you contact the NSA for some of your browsing history jk
It probably was a one time thing, from a sketchy site which was open at the same time as YouTube or a sketchy Google Ad (Which I doubt)
https://linustechtips.com/topic/269532-ftxt-download/#findComment-3659225
You have their phone number so I can call them?
So I probably shouldn't be worried about any repercussions of this incident? That is what I was thinking from the beginning, but I like to play it safe. Re-imaging is such a PITA, so I really don't want to.
https://linustechtips.com/topic/269532-ftxt-download/#findComment-3659346
