Hey guys, I was wondering if the parts I chose are half decent. I'm not entirely sure on the PSU, Mobo or Sound Card. Any suggestions of alternatives are welcome :)
Thanks!
http://uk.pcpartpicker.com/p/177vS
Setup: i5 4670k @ 4.2 Ghz, Corsair H100i Cooler, Corsair Vengeance Pro 16GB Ram @ 1600 Mhz, MSI Z87-GD65 Motherboard, Corsair GS700 2013 edition PSU, MSI GTX 770 Lightning, Samsung EVO 120 SSD + 2TB&1TB Seagate Barracudas, BenQ XL2411T Monitor, Sennheiser HD 598 Headphones + AntLion ModMic 4.0
https://linustechtips.com/topic/26929-first-build/
You could go with the cheaper cx600 instead for a psu--or any good ~600w bronze psu for that matter.
It looks solid but you could do with a cheaper motherboard without losing any noticeable performance.
https://linustechtips.com/topic/26929-first-build/#findComment-341874
Well the reason why I chose that particular PSU is because is has a blue lighting effect to go with the heat sinks on the Mobo.
Don't buy an optical drive and use the extra monies for a higher quality, modular psu.
Wouldn't change anything else. Very nice.
Doesn't the Windows install come on a disc? If it doesn't then I'll spend the money elsewhere.
Out of interest would you have chosen a WD drive had they not been on all the Computex videos?
I would have chosen them regardless. I never really watched the Computex videos which had WD in them.
Also thanks everyone for giving feedback. I appreciate it :)
https://linustechtips.com/topic/26929-first-build/#findComment-342041
Nice thing about the psu. I didn't know that.
You can install Windows via usb.
WDCaviars /Seagate barracudas are both great.  I recommend Pick whichever is cheapest at the time.
https://linustechtips.com/topic/26929-first-build/#findComment-342060
Oh yeah, Completely forgot about that. I'll see what I can do with that extra cash :)
Thanks!
https://linustechtips.com/topic/26929-first-build/#findComment-342066
I would get one of the newer nzxt cases, since that one is very outdates and lacks some features you may want (usb 3)
Maybe the 820, 630 or switch 810?
Intel 4770k   -   Corsair Vengeance Pro CL9 16gb 1866mhz   -   Corsair Air 540   -   Gentle Typhoon AP45   -   Corsair ax1200i   -   Razer Death Adder 2013   -   Filco Majestouch 2   -   Crucial m4 256gb ssd   -   1TB Western Digital Black   -   Asus Maximus vi Formula   -   Bitspower matte black fittings   -   Black Ice sr1 240mm and 360mm Radiators   -   Swiftech mcp655   -   EK x-res pump top   -   Promochill Advanced lrt 3/8 5/8 bloodshed red tubing   -   swiftech apogee hd cpu block   -   Asus pb278q 1440p monitor   -   Razer Carcharas Headphones   -   Razer Vespula Hard Mouse Pad   -   Arctic Silver 5 TIM   -   Sapphire r9-290x   -   Ek-fc R9-290x Waterblock and Backplate
https://linustechtips.com/topic/26929-first-build/#findComment-342081
Yes, the Windows .iso does come on a disk. But you can get that .iso anywhere and then use your flash drive to install Windows. It's that code on the package you pay the $99 for.
Take a look at some guides. It's pretty easy to do and I think it makes for a faster install.
https://linustechtips.com/topic/26929-first-build/#findComment-342096
Oh, I didn't notice that about the case. Thanks for the heads up :) I'll change over to the Phantom 410.
Ah, That's pretty cool. I'm guessing using a virtual drive (Like MagicDisc) wouldn't work. I might just keep the Drive for when I want to play watch a DVD or something.
https://linustechtips.com/topic/26929-first-build/#findComment-344175
