Cable Extension Kits
Go to solution Solved by Enderman,
Modular power supplies have a custom interface. You cannot plug these cables directly into the PSU, they must be plugged into the cables coming from your PSU.
http://www.pccasegear.com/index.php?main_page=product_info&cPath=19_1424&products_id=29075
Can I plug these straight into the PSU? Or do PSUs have proprietary plugs on them? I know they're extension cables but my current ones are long enough, I just like the look of them.
CPU: i7 2600 @ 4.2GHz  COOLING: NZXT Kraken X31 RAM: 4x2GB Corsair XMS3 @ 1600MHz MOBO: Gigabyte Z68-UD3-XP GPU: XFX R9 280X Double Dissipation SSD #1: 120GB OCZ Vertex 2  SSD #2: 240GB Corsair Force 3 HDD #1: 1TB Seagate Barracuda 7200RPM PSU: Silverstone Strider Plus 600W CASE: NZXT H230
CPU: Intel Core 2 Quad Q9550 @ 2.83GHz COOLING: Cooler Master Eclipse RAM: 4x1GB Corsair XMS2 @ 800MHz MOBO: XFX nForce 780i 3-Way SLi GPU: 2x ASUS GTX 560 DirectCU in SLi HDD #1: 1TB Seagate Barracuda 7200RPM PSU: TBA CASE: Antec 300
https://linustechtips.com/topic/269273-cable-extension-kits/
They're extensions, they plug into the cables that come out of your psu. (They can NOT be plugged directly into the psu itself).
You'd have to get a set up cables specifically for your psu if you don't want to use the default cables at all.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/269273-cable-extension-kits/#findComment-3656284
https://linustechtips.com/topic/269273-cable-extension-kits/#findComment-3656287
Thought so. I have nowhere to hide the cables in my current case, guess I'm going to have to do with what I have now.
https://linustechtips.com/topic/269273-cable-extension-kits/#findComment-3656289
