Well I just got cod 4 off of steam and I downloaded it and then I installed it no problem but when I click play the game starts but I cannot see the game I can only hear the game.So this is what I have tryed to do so far. I have reinstalled it...same thing then verifyed installation and every thing is good.So what do I do now?
Thanks in advance! B)
P.s I do see this splash screen then the above happens
Splash screen: thm_24349a.jpg
https://linustechtips.com/topic/269233-plz-help-cod/
What exactly is happening? Is it going black screen?
Do you have any Anti Virus/ Malaware running?
Is your system able to run it spec wise?
Just remember: Random people on the internet ALWAYS know more than professionals, when someone's lying, AND can predict the future.
i7 9700K (5.2Ghz @1.2V); MSI Z390 Gaming Edge AC; Corsair Vengeance RGB Pro 16GB 3200 CAS 16; H100i RGB Platinum; Samsung 970 Evo 1TB; Samsung 850 Evo 500GB; WD Black 3 TB; Phanteks 350x; Corsair RM19750w.
Laptop: Dell XPS 15 4K 9750H GTX 1650 16GB Ram 256GB SSD
sex hahaha
https://linustechtips.com/topic/269233-plz-help-cod/#findComment-3655846
1.yes the screen goes black but I can hear the game.
2.yes AVG
3.yes GPU is a amd r9 280x
Try disabling AVG. My Anti virus stopped me from downloading a game before.
sex hahaha
https://linustechtips.com/topic/269233-plz-help-cod/#findComment-3655873
ok I tryed it but still same problem
I had the exact issue you where having with Civ V before... Can you Alt + Tab out of the game onto desktop?
sex hahaha
https://linustechtips.com/topic/269233-plz-help-cod/#findComment-3655898
Ya thats the only way I can close the game.
I was having a similar issue on a different game... Try waiting for it to load (Seems kinda obvious but give it some time).
If that doesn't work restart your computer then try.
If neither of these work I don't know.
sex hahaha
https://linustechtips.com/topic/269233-plz-help-cod/#findComment-3655937
