low fps sli
Go to solution Solved by vlkn´,
1. Get a new PSU
2. Place the Graphicscard with the most amount of VRAM (only 2gb and 4gb) on the top
3. If you only got 2GB vram and the game needs more than 2GB, it´s starting to "lagg"
If you want to see if the game does want to use more vram as it can provide, you can download Msi afterburner and configure it to display while you are gaming.
I was playing crisis 3 with Sli 770s and the first time I tried to play it, it almost lagged out so I restarted my computer but I'm only getting 40 flat fps no dips no upward spikes it's weird.
Oh and side note when I was running the first time and it lagged out I got a message from windows "crisis 3 is using high amounts of memory." and I'm pretty sure I enabled Sli on GeForce
Case: RebateCorsair Vengeance Series C70 Military Green Steel
Mobo: GIGABYTE GA-Z97X-Gaming 5 LGA 1150
Ram: G.SKILL Ripjaws X Series 8GB (2 x 4GB)
Cpu: i5 4670k haswell
Operating: Microsoft Windows 8.1 64-bit
GPUs: asus 770 oc and evga 770
Watercool: corsair H100i
POWER!: sea gate 650watt modular bronze
Steam:Drift and Drift_2 <p>(name is hunter) Lets play:)
https://linustechtips.com/topic/269224-low-fps-sli/
650 watts with 2 770s is cutting it too close... Did you OC your cards?
The BBQ: i7-4770 / 212x / Tri-X R9 290x 1075/1400 / MSI H87-G43 GAMING / EVGA G2 850W / Corsair Spec 03 / Samsung 840 EVO 250gb SSD / Toshiba 2TB HDD / 8gb Kingston DDR3 1600mhz
Peripherals: G710+ / G502 / Bose Companion 2 Series III / Audio Technica ATH-M40x / Sound Magic E50
Monitors: Dell U2414H
https://linustechtips.com/topic/269224-low-fps-sli/#findComment-3655736
No, I don't have them oc and could you reply on other posting above this one? For some reason it double posted this
Edited by docterkiwi
https://linustechtips.com/topic/269224-low-fps-sli/#findComment-3655745
Try disabling one of the cards and seeing how your FPS is.
Then see if it scales in other games.
Just remember: Random people on the internet ALWAYS know more than professionals, when someone's lying, AND can predict the future.
i7 9700K (5.2Ghz @1.2V); MSI Z390 Gaming Edge AC; Corsair Vengeance RGB Pro 16GB 3200 CAS 16; H100i RGB Platinum; Samsung 970 Evo 1TB; Samsung 850 Evo 500GB; WD Black 3 TB; Phanteks 350x; Corsair RM19750w.
Laptop: Dell XPS 15 4K 9750H GTX 1650 16GB Ram 256GB SSD
sex hahaha
https://linustechtips.com/topic/269224-low-fps-sli/#findComment-3655751
So I tested taking one card out and was getting like 24 FPS with single card and Max graphics. Do you think somehow my cards are underclocked somehow.
https://linustechtips.com/topic/269224-low-fps-sli/#findComment-3655894
What's your recommended power supply?
EVGA G2 750 watts. On pc part picker your system draws 638 watts, how the heck are you running that PC with just 650 watts 80+ bronze? I highly doubt that your 2nd card is active. Either that or both cards are sort of forced to undervolt/underclock to accommodate the lack of power. Change PSU immediately, I personally would get the EVGA G2 850 watts for room to OC the living crap out of my CPU and GPUs
https://linustechtips.com/topic/269224-low-fps-sli/#findComment-3655921
Good idea I'll try that in the morning
According to my brother (who is an electrical engineer) he said that if your PSU isnt strong enough to pump out the wattages your PSU and parts will be damaged. I suggest running a single 770 till you can afford the new PSU i suggested above
https://linustechtips.com/topic/269224-low-fps-sli/#findComment-3655935
1. Get a new PSU
https://linustechtips.com/topic/269224-low-fps-sli/#findComment-3655959
Depends on a number of things like power draw per rail. If the 12V rail(s) is/are fine, the components running on THAT rail or rail system won't be damaged. Even so, the protection circuitry should kick the power supply as far as I'm concerned.
https://linustechtips.com/topic/269224-low-fps-sli/#findComment-3657030
Also had that issue with high amounts of memory when i was running 8GB ram in Crysis, BF4 and pretty much most games. i think you should try adding another 2x4gb sticks or get 2x8GB sticks.
Check gpu temps. i've also heard that the vrm is not being cooled well enough on the asus GTX770 so maybe it's a problem with your vrm on the ASUS card
https://linustechtips.com/topic/269224-low-fps-sli/#findComment-3657033
