So i'm OCing my GPU (Afterburner W/ a 980)... The Power keeps going to 51%, and the coreclock to 529.... The only way I found to stop this is to restart... It's not near the max temps I set through Afterburner... This is canabalizing my FPS in games too... Halp!
Just remember: Random people on the internet ALWAYS know more than professionals, when someone's lying, AND can predict the future.
i7 9700K (5.2Ghz @1.2V); MSI Z390 Gaming Edge AC; Corsair Vengeance RGB Pro 16GB 3200 CAS 16; H100i RGB Platinum; Samsung 970 Evo 1TB; Samsung 850 Evo 500GB; WD Black 3 TB; Phanteks 350x; Corsair RM19750w.
Laptop: Dell XPS 15 4K 9750H GTX 1650 16GB Ram 256GB SSD
sex hahaha
https://linustechtips.com/topic/269037-gpu-going-12-power/
So i'm OCing my GPU (Afterburner W/ a 980)... The Power keeps going to 51%, and the coreclock to 529.... The only way I found to stop this is to restart... It's not near the max voltage I set through Afterburner... This is canabalizing my FPS in games too... Halp!
ITs called throttling. What are the GPU temps?
CPU: AMD FX8350 @4.4GHz | MOBO: ASUS Sabertooth 990FX R2.0, 990FX chipset | RAM: 16GB (4x4) dual channel Patriot Xtreme series DDR3 @1866MHz @1.65V | GPU: Asus Radeon R9 Fury Strix| PSU: Corsair AX860i 860 watt | CPU cooling: Noctua NH-D15S + additional Noctua NF-F12 | Case:Corsair C70 Black | Storage: 3x 128GB Samsung 840 pro SSDs; 1 for the OS, 2 in RAID 0 for games. 3x WD Red 3TB HDDs in raid 5 for bulk storage | Displays: 1x Dell 3007WFP 30 inch 2560x1600 IPS LCD. 1x I-Inc IH253DPB 25 inch 1920x1080 TN LCD | Keyboard: Corsair K70 with Cherry MX brown switches + Blue LED backlight | Headphones: Sennheiser HD 280 Pro | Mouse: Logitech G600 @1100 DPI | OS: Win 10 Pro 64 bit |
Mfg/model number: Clevo/W355SSQ | CPU: Intel i7 4710MQ @3.5GHz  | MOBO: W35xSS_370SS, HM87 Chipset | RAM: 16GB (2x8) dual channel Crucial Ballistix DDR3 @1866MHz | GPU: GTX860m 2GB Gddr5 | Battery: 76,960mW/h 8 Cell battery, 3 Hrs full on a full charge | Storage: 1x 128GB Samsung 840 pro SSD for the OS. 1x WD Red 1TB HDD For storage and games | Displays: 1x 15.6" 1080p LCD | Keyboard: Full 103 key back-lit keyboard | Mouse: Logitech M510 | OS: Win 10 Pro 64 bit |
https://linustechtips.com/topic/269037-gpu-going-12-power/#findComment-3653361
Mid 60's... The max is set to 85...
sex hahaha
https://linustechtips.com/topic/269037-gpu-going-12-power/#findComment-3653404
weird
Are you new to the forums???? read the Code of Conduct HERE WANT SOME AWESOME LTT THEMED WALLPAPERS??? check out XTanksSlayerX's wallpaper thread HERE
"May our framerates be high, and our temperatures low" - PC MasterRace
https://linustechtips.com/topic/269037-gpu-going-12-power/#findComment-3653500
What clocks you trying to achieve?
https://linustechtips.com/topic/269037-gpu-going-12-power/#findComment-3653505
weird
Could it be GPU boost 2.0 messing with it? I can't find where to change that at...
sex hahaha
https://linustechtips.com/topic/269037-gpu-going-12-power/#findComment-3653508
+209 Core +180 VRAM
even @ stock it does dis...
sex hahaha
https://linustechtips.com/topic/269037-gpu-going-12-power/#findComment-3653515
So how are you testing it? Besides in game? Does it do it while not over clocked?
https://linustechtips.com/topic/269037-gpu-going-12-power/#findComment-3655214
I was using MSI Kombustor... It did happen when not overclocked...
sex hahaha
https://linustechtips.com/topic/269037-gpu-going-12-power/#findComment-3655688
So what does the gpu usage do during all this?
https://linustechtips.com/topic/269037-gpu-going-12-power/#findComment-3655842
