Quick Question About CPU Voltage settings
Go to solution Solved by Enderman,
also what is the difference between offset and manual ?
i didnt know there was an offset option...
idk what its for
EDIT- this should explain it well: http://rog.asus.com/51092012/overclocking/overclocking-using-offset-mode-for-cpu-core-voltage/
So am trying to change my motherboard voltage, so i can overclock my cpu by a little bit to 3.8 Ghz  but am kinda confused
here is the menu of the voltage
now am confused as when I press +  it does that and am confused if that adds onto the voltage shown on the left.
and lastly am not sure if I input the same exact voltage it adds onto that or stays like that can anyone help clarify  ?
NEVER GIVE UP. NEVER STOP LEARNING. DONT LET THE PAST HURT YOU. YOU CAN DOOOOO IT
https://linustechtips.com/topic/268600-quick-question-about-cpu-voltage-settings/
Setting the voltage manually does not add it to the 1.236v. It sets it to whatever value you put in the box.
idk what its for
