So I replace my SP120s that were on my H100i with some Noctua NF-F12s. Also replace rear intake with a Noctua NF-F12 and replace front intake with a CM megaflow. Have to say PC is running nice and quiet. I also add more ram from 8GB to 16GB.
Spec:
MOBO: MSi BigBang Z77 Mpower
CPU: i5 3570k OC 4.2Ghz
CPU Cooler: Corsair H100i w/ Noctura NF-F12 in pull
Memory: Crucial Ballistix Tactical Tracer 16GB @ 1866
GPU: EVGA GTX 680 FTW+ 4GB
Boot drive: Sandisk Extreme 120GB
Storage: WB VelociRaptor 600GB
PSU: Corsair AX850
Case: Corsair 600T white
Parvum Systems S1.0, 3570K, H100i, Asus Maximus V Gene, Crucial Ballistix Tactical Tracer 16GB @ 1866, EVGA GTX 680 FTW+, Samsung 840 Pro 128GB SSD, WD Velociraptor 600GB HDD, Corsair AX850
https://linustechtips.com/topic/2686-update-new-parts/
Nice clean look you got going there, good job!
Come and join the awesome Official LTT Star Citizen Org at LTT Conglomerat,  GTA 5 LTT Crew at LTT Conglomarate
PC Specs - 4770k - OC 4.5GHz  - GTX 780 SC - 16GB HyperX - NZXT H440 White - Corsair H100i - Corsair AX750 - Samsung Evo 250GB - 2 x PA238Q - ATH-M50 -
https://linustechtips.com/topic/2686-update-new-parts/#findComment-37676
nice work how are those fans on the h100i did it drop ur temps
not realy. since that max speed for the NF-F12 is 1500rpm. the temps are the same. the SP120s were set at 1264rpm but they are loud. i have the NF-F12 set at 1000rpm. nice and quiet and same temps. idle 29c. any game i throw at it cpu stays at a nice 43c and stable. mind you my 3570k is OC to 4.2Ghz. since its a maintance free sealed water system it pretty good. if i went eith a full custom i can keep the cpu at ilde temp even under gaming load. but that will be in the future. and i'll also watercool the GPU. but i'm new to PCs and not realy to try doing full water cooling just yet.
https://linustechtips.com/topic/2686-update-new-parts/#findComment-37988
DAT CASE =D !! nice build...
thanks. i did post a build thread but somehow it was deleted. so this is just a update post
https://linustechtips.com/topic/2686-update-new-parts/#findComment-38538
The good thing is that you got to hide those hideous Noctua's haha. Performance before appearance' date=' I guess. :)[/quote']
in person they don't look bad. they are pretty heavy due to the motor. fans feels well made and strong. trule lives up to there high price.
https://linustechtips.com/topic/2686-update-new-parts/#findComment-39786
