Would it be possible to use a switch (like an on/off switch) as a button. I was thinking that if you flipped the switch on and off quickly it would serve the same purpose as a button, which is delivering a short amount of current to do something. I was thinking specifically for a computer where the power button sends a pulse to the motherboard to indicate the process of turning on or off the computer. Wouldn't it do the same thing to flip a switch on and off posing as the power button for a computer? Maybe I am misunderstanding how the switch and button work. I was just thinking about this and didn't see why it wouldn't work to replace the button with a switch (on/off switch).
https://linustechtips.com/topic/268518-using-a-switch-as-a-button/
For a computer, yeah, a switch is fine - ONLY - if its not on constantly. It needs to be an intermittent thing. As you should be aware, holding the power button on any computer will shut it down.
You can get an on/off style switch that is just a toggle. Just like a button, but instead of a button it's a rocker.
D3SL91 | Ethan | Gaming+Work System | NAS System | Photo: Nikon D750 + D5200
I can see having one of these on your pc as your on/off switch being freaking awesome and would probably
feel so badass to use.
Laptop - Lenovo Y50   Keyboard - Corsair K95 RGB Cherry MX Brown   Mouse - Logitech G502 Proteus Core   Mousepad - Razer Firefly
Please read the LTT Code of Conduct before submitting a post
You can.
Theres two types of these. Ones that when you flip it, it stays, and ones that do not. You can find them both.
-snip-
I must find one now!
Senor Shiny: Main- CPU Intel i7 6700k 4.7GHz @1.42v | RAM G.Skill TridentZ CL16 3200 | GPU Asus Strix GTX 1070 (2100/2152) | Motherboard ASRock Z170 OC Formula | HDD Seagate 1TB x2 | SSD 850 EVO 120GB | CASE NZXT S340 (Black) | PSU Supernova G2 750W  | Cooling NZXT Kraken X62 w/Vardars
Secondary (Plex): CPU Intel Xeon E3-1230 v3 @1.099v | RAM Samsun Wonder 16GB CL9 1600 (sadly no oc) | GPU Asus GTX 680 4GB DCII | Motherboard ASRock H97M-Pro4 | HDDs Seagate 1TB, WD Blue 1TB, WD Blue 3TB | Case Corsair Air 240 (Black) | PSU EVGA 600B | Cooling GeminII S524
(Deceased) DangerousNotDell- CPU AMD AMD FX 8120 @4.8GHz 1.42v | GPU Asus GTX 680 4GB DCII | RAM Samsung Wonder 8GB (CL9 2133MHz 1.6v) | Motherboard Asus Crosshair V Formula-Z | Cooling EVO 212 | Case Rosewill Redbone | PSU EVGA 600B | HDD Seagate 1TB
DangerousNotDell New Parts For Main Rig Build Log, Señor Shiny  I am a beautiful person. The comments for your help. I have to be a good book. I have to be a good book. I have to be a good book.
Look for OFF-MOM switches, also called momentary switches.
Here are 108 pages of them! http://www.digikey.com/product-search/en/switches/rocker-switches/1114204?k=OFF-MOM
Happy modding!
This.
The "On" button on a computer just temporarily shorts two pins.  One wire goes to the base of the switch, and one goes to the depressed positon, making a loop whenever the button is pushed.
The reset is the same.
Intel 4670K /w TT water 2.0 performer, GTX 1070FE, Gigabyte Z87X-DH3, Corsair HX750, 16GB Mushkin 1333mhz, Fractal R4 Windowed, Varmilo mint TKL, Logitech m310, HP Pavilion 23bw, Logitech 2.1 Speakers
Happy modding!
Of course the other Ham reccomends digikey. ;)
