Hi Guys,
Just need a network guru to take a look at this setup, will the quad lagg be effective in this setup and will it all be running sweet.
Thanks
post-42018-0-82924000-1418334098_thumb.j
Corsair Obsidian 350D Chassis / i7 4790K @ 4.0Ghz / Asus Strix GTX 970 / 16GB Red Corsair Vengeance Pro @ 1600 Mhz / Asus Maximus VII Gene / Corsair H100i CPU Cooler / Crucial 250GB SSD / Crucial 480GB SSD / Seagate 1T Barracuda 7,200 RPM SATA III / Seasonic G750W PSU / ASUS Vulcan Headset / Corsair M65 / Corsair K70  / Razer Vespula Mouse Mat / 2 x 22" LG 22EA63 Monitors @ 1080p / 1 x 24" BenQ 144 Hz Gaming Monitor -   :P
https://linustechtips.com/topic/268399-new-small-business-network-setup-help/
This needs to be Linus's new office.
My hope is in some strange way it turns out it is xD
CPU Ryzen 5 Asrock B350 Pro 4 / MSI RX580 Gaming / RAM 16 Gigs Corsair Vengeance 3000 / HDD 1TB Seagate Barracuda / SSD Samsung 840 120GB / 500GB Samsung SSD / Case Urban S31 / PSU EVGA G2 750w / Os Windows 10 / Keyboard Corsair K70 / Mouse Razer Naga 2013 (Won it from Linus!!
I'm guessing you'll be working a lot with the nas server.
I doubt you need 4G uplinks between switches, but being in the same office you will probably use cat5 cable and won't cost much.
You should setup as Cacti server and add the switches with SNMP so you can monitor the network and spot any potential bottlenecks or faulty links.
Hi costin, the idea is to use cat5e and yh we will be accessing the server a lot...
What brand of switches are you using?
I plan on using Netgear managed switches, unless anyone has better suggestions?...
Also added in 4 more laptop bays to the left of the open air test bench  :P
I never used netgear so idk how they are.
The cheapest gigabit managed switches i use are zyxel gs series and they are ok.
If it wore up to me and not thinking of the budget, i'd use cisco 2960g or 3560g
Went for these in the end - http://www.scan.co.uk/products/24-port-netgear-gs724t-prosafe-gigabit-10-1000-smart-network-switch
Can you aggregate ports on them ?
Yes it supports 802 ad which is LACP Link aggregation
Sorry, Networking Student here, what's a Quad LAGG, feel like that's something I should know and Google was not very helpful...
HexCase: Corsair iCUE 5000X RGBCPU: Ryzen R7 3700X  | MOBO: Asus TUF Gaming X570-Plus | GPU: Gigabyte RTX 2070 Super | RAM: G.SKILL Ripjaw DDR4-3600 16GB | SSD: Corsair MP600 1TB & 480 GB EVO | HDD: 4tb WD Black & 3TB WD Green | PSU: EVGA SuperNOVA 850 G+ | Cooler: CORSAIR iCUE H100i RGB PRO XT, | Monitor: Acer Predator X34 | Keyboard: Corsair K70 RGB | Mouse: Logitech Hero | OS: Windows 11 | Speakers: Audioengine A5+ | Headset: Kingston HyperX Cloud 2 | Laptop/Tablet: TBD | Phone: Samsung Note 9 | PS4 | Xbox One | TV Sony XBR55X900F
a quad lagg is when you connect one switch to another with multiple network cables, in this case 4 cables between the switches. this will increase bandwidth. as its 4 cables transferring data over one.
NAME: HAF Satlite MOBO: ASUS Maximus Extreme-Z IV CPU: i5 3570K 4.4GHz 1.256V GPU: ASUS 1080Founders RAM: 4x4GB Corsair Vengeance Red 1600MHz 7-8-8-24 PSU: EVGA 750W Gold STORAGE: 1TB Samsung Evo | 4x4TB WD Green Raid10 OS: 10 x64 Pro COOLING: Custom 360rad CPU under water soon GPU too
NAME: Node Box Server MOBO: Intel DB55SB CPU: i5 750 GPU: ASUS 560DC OC 1GB RAM: 2x2GB Corsair XMP 1333MHz PSU: Coolermaster 1000W Bronze STORAGE: 90GB Corsair FORCE Jails| 5x4TB WD Raidz2 60GB Corsair Force Cache OS: Freenas COOLING: Back to Stock
He just means link aggregation, LAGG is a BSD package that allows you to do it.
The protocol for it that you're most likely familiar with is probably LACP (Link Aggregation Control Protocol).
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
Ahhh, yeah we were calling that Link Aggregation or multi-trunking. Thanks guys.
We've configured switches in general, but never for Link Aggregation, hopefully they'll cover that and LAGG/LACP in my final year. Thanks again.
He could have a large office and its hard to get all the cables in the same spot.
Correct, my original plan had a 48 port switch, but the layout of the office made it much more difficult
Thanks for clearing that up Blade of Grass - I'm pretty new to networking so this will be my first time using Link Aggregation, I've read up a lot about it so hopefully this will be a successful venture  :huh:
