Hey guys, I've been having issues with my Xonar DX sound card & Sony MDR V6 Studio Headphones, not entirely sure what's causing it but the audio exhibits horrendous crackling especially with bass, I've read that I might need a headphone amp, although I bought the Xonar DX thinking that it already had a very decent headphone amp.
Any idea how I can diagnose this issue ?
The crackling is clearly evident in this video especially at the bass heavy beginning.
http://www.youtube.com/watch?v=gFD7NTDrAqE
https://linustechtips.com/topic/26822-audio-cracklingpopping/
Have you adjusted the equalizers at all? Do you have Crossover Frequency adjustment?
https://linustechtips.com/topic/26822-audio-cracklingpopping/#findComment-340656
My Samson SR850 with a Xonar DGX also pop/crackle in this video. It is the first time I notice something like that. Maybe it is too bass heavy for our soundcards.
By the way, the Xonar DX doesn't have a headphone amp.
Edited by Stav Kats
CPU: AMD FX-6100 Black Edition @3.9GHz GPU: XFX 7970 DD (1062/1520 MHz) MOBO: ASUS Sabertooth 990FXA(1st Revision) RAM: Corsair Vengeance 16GB @ 1333MHz Storage: Corsair Force 3 120GB(Boot) + WD Green 1TB(storage) PSU: FSP AURUM 600W(80+ Gold) CPU Cooler: Cryorig M9a  Case: NZXT Tempst 410 Elite(Mid-Tower) Mouse: Logitech G602(Manufacturer Refurbished) Keyboard: Noppoo Choc Mini(Cherry MX Blue) AUDIO:Sennheiser HD 598+ASUS Xonar DGX Monitor: LG M2280DF 21.5" 1080p(TN-75Hz)
https://linustechtips.com/topic/26822-audio-cracklingpopping/#findComment-340670
I just listened to the beginning of the song, and I'm getting some crackling too.
https://linustechtips.com/topic/26822-audio-cracklingpopping/#findComment-340675
Yes & no, although the crackling remains exactly as is even with the equalizer at default and crossover frequency disabled.
The more I read about it the more I think I need an amp, my headphones have an impedance rated at 62 OHMs at 1Khz.
By they way, I have 0 craclking with my cheapo headphones plugged into the soundcard or the onboard audio.
https://linustechtips.com/topic/26822-audio-cracklingpopping/#findComment-340676
if it's your recording, lower the recording volume.
if it's not, stop listening to music on youtube.
Will work for electronic components and parts
Reviews: Meelec CC51P - Monoprice 8323 - Koss Porta Pros  - Shure SRH-440 - Shure SRH-550DJShure SRH-840 - Hifiman He-500 - iBasso D4 - o2 Amplifier  -  SkeletonDac
https://linustechtips.com/topic/26822-audio-cracklingpopping/#findComment-340682
Something tells me it's the quality of the song. I watched a video the other day with so much bass I could feel the speakers vibrating the plastic behind them, but it was crystal clear.
https://linustechtips.com/topic/26822-audio-cracklingpopping/#findComment-340683
I don't know if I can recommend you the Xonar DGX after hearing that popping sound in this video but it is the first time hearing it. Maybe it is worth a try since it is so inexpensive.(The PCI version costs 30$ and the PCI-e version costs 40$)It is capable to handle more than 62 Ohms.
https://linustechtips.com/topic/26822-audio-cracklingpopping/#findComment-340687
No it's not, but I hear the exact same crackling when I play that song on http://www.virtualpiano.net/ , so it's not the recording.
Yes it's weird, I listened to the infamously bass heavy Skyrim theme song again & again with no crackling what so ever.
https://linustechtips.com/topic/26822-audio-cracklingpopping/#findComment-340695
I already own the Xonar DX, which is a significantly more expensive sound card, (costs slightly more than double the DGX)
https://linustechtips.com/topic/26822-audio-cracklingpopping/#findComment-340697
I also didn't mention that I was using headphones for both the embedded video and the video I mentioned.
https://linustechtips.com/topic/26822-audio-cracklingpopping/#findComment-340700
But the DX is not ment for headphones,  it is ment for speakers. No matter how much more it costs than the DG/DGX, it is not fir listening with headphones. The DG/DGX are headphone "optimised".
https://linustechtips.com/topic/26822-audio-cracklingpopping/#findComment-340723
are you getting the same cracking outside of virtual piano?
https://linustechtips.com/topic/26822-audio-cracklingpopping/#findComment-340780
I hear the crackling too, even on my O2 and He-500 each of the "keys" is a recording of a real piano, but they didn't do anything to keep playing the audio between tracks or smooth the clipping at the beginning and end of each sound effect.  How terrible.  They should learn 2 flash.
I think I will just go ahead & order an amp & report back if the crackling is gone, any recommendations ? I just want something simple for around 40$ or less.
Buying more sound equipment won't fix clipping in a recording.
"Pardon my French but this is just about the most ignorant blanket statement I've ever read. And though this is the internet, I'm not even exaggerating."
https://linustechtips.com/topic/26822-audio-cracklingpopping/#findComment-341409
Your "cheapo" headphones don't even respond at the frequency where this effect occurs, which is why they ironically sound better.
https://linustechtips.com/topic/26822-audio-cracklingpopping/#findComment-341418
That's what I thought too.
Thanks everyone for your replies !
https://linustechtips.com/topic/26822-audio-cracklingpopping/#findComment-342288
