Workstation + Consumer card in same PC?
I wouldn't bother doing any serious gaming with WS cards.
If you happened to upgrade to a Tesla, Quadro, Titan, etc. you would have to upgrade your CPU because it would be a bottleneck
Not necessarily. Bottlenecking can happen depending on the usage and bottlenecks that could occur for gaming often don't translate to usages outside of gaming--especially when it comes to content creation where resources are much better optimized than games.
Wouldn't that cause driver issues to crop up? How would you solve any that do?
Thanks guys, please keep the ideas and pros/cons coming. If anyone doesn't know about the workstation+consumer setup, but can speak to whether (and what) workstation cards can play games like Tomb Raider/Dragon Age Inquisition at framerates better than an old HD5870, that is also extremely good information.
There shouldn't be issues. Different graphics cards should be able to work independently just fine in a system.
Due to the differently optimized drivers, WS cards will often fall quite behind their consumer card equivalents for gaming: http://www.tomshardware.com/reviews/workstation-graphics-card-gaming,3425-6.html
It shouldn't be too hard to get a WS card that games better than a 5870 though.
So the only way to do it is to install/reinstall drivers constantly? That's...a huge pain. Is that how the LTT guy in the watercooling video is running 2x Titans + Quadro?
No need to reinstall drivers. Just install drivers for the cards you have and let them run independently.
If you can use a Titan or a consumer grade card for what you're doing, then do that. If that's not possible, look into what WS options are within your budget and see if they perform well enough for what you're doing including gaming.
