Sorry to bother, which is the best power supply producer for my pc.
My build:
Motherboard: MSI Z77A-G43
Procssor: Intel i5 3570
Memory: 2x4 gb Kingston HyperX Blu 8GB DDR3 1600MHz CL9
HardDrive: 1tb WD EZEX SataIII
Video Card: MSI R7870 Twin Frozr 2GD5/OC
Waiting for your answer, thanks.
https://linustechtips.com/topic/2667-psu-help-thanks/
Grab an XFX 550W PSU, they are manufactured by SeaSonic who are a reputable brand and can be found for dirt cheap. Another suggestion would be a Rosewill HIVE 550W, it's semi-modular, great quality and can be found for $60 on newegg. 550W will be more than enough to power your system, either PSU will do the job.
https://linustechtips.com/topic/2667-psu-help-thanks/#findComment-35343
For this setup I suggest you a 500 watt power supply from Corsair for example.
You could take this power supply. With this you have enough for your current build and you can maybe upgrade in future: http://www.corsair.com/en/power-supply-units/tx-series-power-supply-units/enthusiast-series-modular-tx550m-80-plus-bronze-certified-550-watt-high-performance-modular-power-supply.html
https://linustechtips.com/topic/2667-psu-help-thanks/#findComment-35466
Thanks for the promptness of responses. I am from Romania, and can not order on New Egg, because it is expensive to transport here. I wanted to take this (XFX 550W PSU) but not found in Romania, so I have to choose between these:
Cooler Master GX-550W,
Seasonic S12II-520 Bronze 520W
Corsair Builder Series CX600 V2 (I heard they have problems). I have $ 100.
If you know a better one in this money, please tell me.
Sorry for my English.
https://linustechtips.com/topic/2667-psu-help-thanks/#findComment-36712
Thanks for the promptness of responses. I am from Romania' date=' and can not order on New Egg, because it is expensive to transport here. I wanted to take this (XFX 550W PSU) but not found in Romania, so I have to choose between these: Cooler Master GX-550W, Seasonic S12II-520 Bronze 520W Corsair Builder Series CX600 V2 (I heard they have problems). I have $ 100. If you know a better one in this money, please tell me. Sorry for my English. [/quote']
Seasonic are one of the best PSU manufacturers in the world, I would definitely pick the Seasonic.
https://linustechtips.com/topic/2667-psu-help-thanks/#findComment-37525
What are the prices of the Cooler Master and the Seasonic? The Seasonic is better, but the Cooler Master is fine too, so it's not worth spending a lot more on the Seasonic.
https://linustechtips.com/topic/2667-psu-help-thanks/#findComment-37573
Cooler Master GX-550W, - 120$ (with VAT)
Seasonic S12II-520 Bronze 520W - 130$ (with VAT)
https://linustechtips.com/topic/2667-psu-help-thanks/#findComment-38573
Corsair, XFX, Seasonic, FSP, PCP&C, Super Flower, Enermax (among others) are all good brands. Don't waste you money on anything over 550-600 Watts. PSU's are most efficient when running 60-80% load. Stay away from Cooler Master, Raidmax, Dynex, or anything that came with the case.
"Energy drinks don't make my mouth taste like yak buttholes like coffee does, so I'll stick with them." - Yoinkerman
https://linustechtips.com/topic/2667-psu-help-thanks/#findComment-38601
