Hello, me again (last time i swear). My video cards (2x MSI GTX 970s) just came in. I was told the motherboard (MSI z97s sli krait) or the cards would come with an sli bridge but it does not appear to be the case. Ive been told i may not need them and that my mb would do bridgeless sli. Dont know if i believe this because ive recieved a lot of conflicting info on the subject. Is this true or do i need to buy a bridge?
https://linustechtips.com/topic/266614-sli-bridge-problems/
You need to by a Bridge. Nvidia cards don't do Bridgeless SLI
|King Of The Lost|
Project Dark: i7 7820x 5.1GHz | X299 Dark | Trident Z 32GB 3200MHz | GTX 1080Ti Hybrid | Corsair 760t | 1TB Samsung 860 Pro | EVGA Supernova G2 850w | H110i GTX
Lava: i9 12900k 5.1GHz (Undervolted to 1.26v)| MSI z690 Pro DDR4| Dominator Platnium 32GB 3800MHz| Power Color Red Devil RX 6950 XT| Seasonic Focus Platnium 850w| NZXT Kraken Z53
Unholy Rampage: i7 5930k 4.7GHz 4.4 Ring| X99
Rampage|Ripjaws IV 16GB 2800 CL13| GTX 1080 Strix(Custom XOC Signed BIOS) | Seasonic Focus Platinum 850w |H100i v2
Revenge of 775: Pentium 641 | Biostar TPower i45| Crucial Tracer 1066 DDR2 | GTX 580 Classified Ultra | EVGA 650 BQ | Noctua NH D14
https://linustechtips.com/topic/266614-sli-bridge-problems/#findComment-3621889
You cannot do bridgeless SLI. It doesn't work that way.
https://linustechtips.com/topic/266614-sli-bridge-problems/#findComment-3621899
Nvidia still needs an SLI bridge
https://linustechtips.com/topic/266614-sli-bridge-problems/#findComment-3621903
No, the only cards that run without a bridge are R9 290/290X's and I believe R9 285s. Everything else needs a bridge
"Rawr XD"
https://linustechtips.com/topic/266614-sli-bridge-problems/#findComment-3621909
That is correct.
https://linustechtips.com/topic/266614-sli-bridge-problems/#findComment-3621929
Just buy an evga pro bridge, I assume money isn't an issue with buying 970(s).
https://linustechtips.com/topic/266614-sli-bridge-problems/#findComment-3622635
