I know this is the not the right spot for this but i thought this was the best forum to ask it in. I have been looking for cable sleeves to help theme my case but I was wondering what people recommend.
Err... Whats with the calendar? lol, but anyway, are you wanting to do the sleeving yourself or have stuff premade?
https://linustechtips.com/topic/266571-cable-sleevings/#findComment-3621388
i want stuff not permanent
Not permanent? Cable extensions would do it... Anyway sleeving your own cables requires a lot of time and patience and an intermediate level of skill. I'd definately say have a look at the BitFenix Alchemy extensions, and pick some out from there that suit your build and match your requirements.
AMD Ryzen 7 9800X3D ASUS ROG Strix B650E-F RTX 5080 Founders Edition  Corsair 32GB 6000MHz CL30 Corsair RM1000x Fractal Design North
https://linustechtips.com/topic/266571-cable-sleevings/#findComment-3621419
Buy some Paracord (obnoxious amount of colors available  very cheap) off eBay and a pin tool to remove the cables from the PSU cable sockets.
This is a lot easier if you have a modular PSU. If you don't, it can still be done, it's just a bit more laborious.
And don't bother with extensions. They look "ok" but they're lazy as fuck. If you want something sleeved don't half ass it, do it right.
https://linustechtips.com/topic/266571-cable-sleevings/#findComment-3621450
There is no real reason to fully sleeved cables. You can't see any difference between fully sleeved and extensions and they are cheap.
https://linustechtips.com/topic/266571-cable-sleevings/#findComment-3621515
you do see the difference, every time you look at that PSU if you don't have a shroud.
There's also some pride in doing it yourself, plus it's probably cheaper if not the same price.
to reiterate, I mean buying the sleeving and doing it yourself.
https://linustechtips.com/topic/266571-cable-sleevings/#findComment-3621532
It also takes quite a few hours so it wouldn't be worth it for me.
https://linustechtips.com/topic/266571-cable-sleevings/#findComment-3621542
It takes awhile to do so. Plus, it actually is cheaper to order it and also neater.
https://linustechtips.com/topic/266571-cable-sleevings/#findComment-3621550
well he can decide that for himself
some people build as a hobby, I wouldn't imagine buying sleeved cables to appeal to someone like that.
And I seriously doubt it's cheaper to buy sleeved extensions for everything.
https://linustechtips.com/topic/266571-cable-sleevings/#findComment-3621620
