I am looking for the best, yet thinnest radiator fans.
In the bitfenix pandora there is 65mm of space for a rad before running into the bracket, which I do not want to remove, and with my silverstone td02, and the fans it is 70mm. So I am looking for a fan that would be a smaller profile, yet still deliver enough air flow for cooling.
https://linustechtips.com/topic/266150-thin-rad-fans/
Check out the ones from that new company that makes that big cooler, c1 ultimate I think? They sell a slim good fan
https://linustechtips.com/topic/266150-thin-rad-fans/#findComment-3615981
You mean this one ?
http://www.cryorig.com/c1.php
That's the company, here is the fan I was speaking of
http://www.cryorig.com/xt140.php
https://linustechtips.com/topic/266150-thin-rad-fans/#findComment-3616064
Not 120. Since it is in the pandora, I am only able to use 120/240mm radiators.
Ah then I don't know.
https://linustechtips.com/topic/266150-thin-rad-fans/#findComment-3616119
Try these:
120mm Akasa AK-FN078
They move a decent amount of air for a thin fan, Could I ask why your fans need to be so slim?
Chernobyl
AMD FX8350 @ 5GHz | Asus Sabretooth 990FX R2 | 16GB HyperX Savage @1950mhz CL9 | 120GB Kingston SSDNow
EK AMD LTX CSQ | XSPC D5 Dual Bay | Alphacool NexXxoS XT45 240mm & Coolgate Triple HD360
Kraken
Intel i5 4670K Bare Die 4.9GHz | ASUS Maximus VII Ranger Z97 | 16GB HyperX Savage 2400MHz | Samsung EVO 250GB
EK Supremecy EVO & EK-MOSFET M7G  | Dual 360mm Rads | Primochill CTR Phase II w/D5 | MSI GTX970 1670MHz/8000MHz
Graphic Design Student & Overall Nerd
https://linustechtips.com/topic/266150-thin-rad-fans/#findComment-3618633
Try these:
The bitfenix pandora has 65mm of clearance for a radiator. The silverstone td02 is 45mm itself, fans are 25, so about 70mm. I am 5mm over. And while yes I can remove the drive cage, I would like to keep it there until I get around to figuring out how to mod the top to turn the drive again.
https://linustechtips.com/topic/266150-thin-rad-fans/#findComment-3618709
AH! I see, well I have this problem too when I fit my 2nd 240mm rad to the front of my 500R, The work around I figured was to make a little plexi/acrylic shroud or shelf (imagine the 900D where it has a lower compartment, basically that) I'm not sure how many drives you have, but I have 2 so I could make a little display for my SSD and the HDD could sit nice and snug on the shelf that covers the PSU. Not only do this allow you to hide all the cables but remove the cages too.
Chernobyl
Kraken
https://linustechtips.com/topic/266150-thin-rad-fans/#findComment-3618744
That is the issue. Where the ssd is mounted on the pandora, for it to show, I have to remove that in order to get enough clearance for the radiator and fans.
https://linustechtips.com/topic/266150-thin-rad-fans/#findComment-3619255
Can you take some pics so I can get a better idea and see if I can offer a solution?
Chernobyl
Kraken
https://linustechtips.com/topic/266150-thin-rad-fans/#findComment-3619335
