Have you stressed your CPU?
https://linustechtips.com/topic/265732-help-with-an-fx-6300/#findComment-3611071
And the CPU never went to your set OC? Did you actually save your settings?
https://linustechtips.com/topic/265732-help-with-an-fx-6300/#findComment-3611106
I tried to oc my cpu which is an FX 6300 with a gigabyte GA 970a ds3p but when I go back to windows and I open CPU-z or other softwares monitoring my cpu at the multiplier says 14-20 and the higher I go the lower the multiplier gets.temps are around 40c max
I have the same CPU and Board, Im prepping for an OC tomorrow.
Did you turned of Turbo boost ? O.o
i5 4690k @ 3.5Ghz | Stock Cooler :/ | ECS Gank Machine Z87H3-A2X EXTREME | Gskill RipjawsX 8GB 1600Mhz | MSI GTX 960 100th ME 2GB | Samsung 840 Evo 120GB | 1TB WD Caviar Blue | Seasonic m12ii evo 750W | Razer Modded Phantom 410
https://linustechtips.com/topic/265732-help-with-an-fx-6300/#findComment-3625075
Yep
Try to follow this vid
I dont understand the language xD
Tell me if its effective, im also going to OC tomorrow
https://linustechtips.com/topic/265732-help-with-an-fx-6300/#findComment-3625487
