Run what? Almost anything can run windows on 4k if you are asking
The BBQ: i7-4770 / 212x / Tri-X R9 290x 1075/1400 / MSI H87-G43 GAMING / EVGA G2 850W / Corsair Spec 03 / Samsung 840 EVO 250gb SSD / Toshiba 2TB HDD / 8gb Kingston DDR3 1600mhz
Peripherals: G710+ / G502 / Bose Companion 2 Series III / Audio Technica ATH-M40x / Sound Magic E50
Monitors: Dell U2414H
https://linustechtips.com/topic/265409-4-k-help/#findComment-3607645
If you are talking about gaming with that setup. No. Prepare to lower all the settings.
Ryzen 3700x -Evga RTX 2080 Super- Msi x570 Gaming Edge - G.Skill Ripjaws 3600Mhz RAM - EVGA SuperNova G3 750W -500gb 970 Evo - 250Gb Samsung 850 Evo - 250Gb Samsung 840 Evo  - 4Tb WD Blue- NZXT h500 - ROG Swift PG348Q
https://linustechtips.com/topic/265409-4-k-help/#findComment-3607710
Yes it'll run it, and you'll be able to play most games at 4k medium or higher settings. Some games like Crysis 3 you may have to turn down the resolution to w/e the arbitrary resolution is for 4k monitors (2880x1620 I think) unless 55fps @ low is acceptable.
RIP in pepperonis m8s
https://linustechtips.com/topic/265409-4-k-help/#findComment-3607770
