I got a Define R4, 2 SP 120's and a Hyper 212 EVO. So i'm gonna attach the 2 SP 120's to the front intakes of the case, that means I end up removing the included fan from the case. So where could I make use of this 140 mm fan? I know I can't attach it to my Hyper 212 EVO because it doesn't support more than 120 mm.
https://linustechtips.com/topic/265294-fan-configuration/
2 sp front, 140 rear
https://linustechtips.com/topic/265294-fan-configuration/#findComment-3606247
Yeah I know there's two 140 mm's included with the case only taking out the front one leaving the exhaust in the case.
O.
2 sp intake
1 140 rear
1 140 side intake if no window, or put it top back
https://linustechtips.com/topic/265294-fan-configuration/#findComment-3606279
Intake or Exhaust?
I got a windowed version.
Which orientation is the 212 in?  Is the fan facing towards the rear exaust or down towards the bottom?  Positive airflow is always better.  In my Node 804 I have four fans intaking, and two exausting.
sold
https://linustechtips.com/topic/265294-fan-configuration/#findComment-3606356
The 212 EVO fan would push air towards the exhaust
https://linustechtips.com/topic/265294-fan-configuration/#findComment-3606391
You don't need more intake than what 2x120mm will bring. Adding another exhaust in the other hand will make the air pressure negative and so not worth it. My friend has 2x140mm in, 1x140mm out and its both cool and quiet.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/265294-fan-configuration/#findComment-3608381
