PSU noise
Solved by Enderman,
Its a design flaw that the temperature control unit has. Every time you hear that noise it is because it sent a small pulse of electricity to the fan for just a second.
It sounds like a leaky faucet or small knock every 10-20 seconds, my AX860i does it too.
My solution was to put the fan at a constant 800rpm instead of the silent mode. This means it does make a bit of fan noise, but it is far less noticeable or annoying as the knocking sound.
Now afaik the GS600 does not have corsair link, so you can control the fan profiles from the OS. So I don't think you can really do anything other than replace the fan (which may or may not stop the sound, i havent tried this yet) or replace the whole PSU ![]()
