How does TDP work?
Go to solution Solved by VincentiusIV,
My CPU has 88w TDP. The dark rock 3 has 190w TDP, sooo, does that mean it's more than double sufficient enough to cool the CPU at stock?
Current PC build: [CPU: Intel i7 8700k] [GPU: GTX 1070 Asus ROG Strix] [Ram: Corsair LPX 32GB 3000MHz] [Mobo: Asus Prime Z370-A] [SSD: Samsung 970 EVO 500GB primary + Samsung 860 Evo 1TB secondary] [PSU: EVGA SuperNova G2 750w 80plus] [Monitors: Dual Dell Ultrasharp U2718Qs, 4k IPS] [Case: Fractal Design R5]
https://linustechtips.com/topic/264454-how-does-tdp-work/
Basically yes.
https://linustechtips.com/topic/264454-how-does-tdp-work/#findComment-3596859
Assuming you don't over clock then yes. When you over clock the tdp goes through the roof.
Build
Mobo: MSI B550 MAG Tomahawk  ||||| Ram: 32 GB GSkill Trident Z RGB ||||| CPU: Ryzen 5800X ||||| GPU: ASUS RTX 3080 TUF OC ||||| Mouse: Logitech G502 ||||| Headset: Sony WH1000XM3 ||||| Keyboard: Logitech G810 Orion Spectrum ||||| Monitors: Acer XG270HU & LG UltraGear 34GP83A-B ||||| AudioStuff: ONKYO DAC HA200 / Audio Techinca ath-ad900x / MXL TEMPO KR USB Condenser Microphone ||||| Storage: 4 TB WD Black --- 2 TB WD Red --- Toshiba 258 GB M.2  ||||| Custom Loop -  Radiators: 3x360 Rad ||||| Case: LianLi O11d XL Black ||||| PSU: Seasonic X series GOLD 1250w
Laptop: Dell XPS 15 9570 4k With a Logitech MX Master
https://linustechtips.com/topic/264454-how-does-tdp-work/#findComment-3596885
Yeah, I'm just wondering how much TDP is generated by overclocking.
https://linustechtips.com/topic/264454-how-does-tdp-work/#findComment-3596895
Now, let's take this to scale, the 8350 normal tdp is 125w, but at around 4.7ghz its about 220w.
Build
https://linustechtips.com/topic/264454-how-does-tdp-work/#findComment-3596913
I will check it out when I get some time later, thanks.
https://linustechtips.com/topic/264454-how-does-tdp-work/#findComment-3596967
It's worth pointing out that be quiet are awful when it comes to quoting tdp, the shadow rock slim (160w) performs better than shadow rock 2 (180w) and my pure rock (130W) fits right in the middle of both of them and I have an 8350 that's running at 4.6 ATM at 39c.
Moral of the story, trust the benchmarks.
https://linustechtips.com/topic/264454-how-does-tdp-work/#findComment-3597246
Basically yes, but it depends on the measurements of the manufacturer.
The cooling capability of an heat sink is positively affected by CPU Temp and air flow through the heat sink and negatively by the ambient temperature.
If one of these values is off from your real life values the given cooling capability is wrong.
https://linustechtips.com/topic/264454-how-does-tdp-work/#findComment-3597330
