Hey guys i have this headset (tritton ax pro) and this may look really dumb, and i dont know much of this and i have a question:
Where do i put each cable, i mean, the headset has 5 cables together, usb, green, orange, pink, black where do i plug it in to the computer, i have a msi z97 gaming 5 mobo and the back of it is like this http://www.pcgameware.co.uk/images/MSI-Z97-GAMING-5-IO-shield.jpg, where do i plug them into ?
Sorry for stupidity and thanks for help
https://linustechtips.com/topic/264441-tritton-ax-pro-to-pc/
You don't have a digital optical coming out of the amp or dac or whatever it is?
Ryzen 3700x -Evga RTX 2080 Super- Msi x570 Gaming Edge - G.Skill Ripjaws 3600Mhz RAM - EVGA SuperNova G3 750W -500gb 970 Evo - 250Gb Samsung 850 Evo - 250Gb Samsung 840 Evo  - 4Tb WD Blue- NZXT h500 - ROG Swift PG348Q
https://linustechtips.com/topic/264441-tritton-ax-pro-to-pc/#findComment-3596613
You would have to look it up in the motherboard manual, it's kind of a stupid motherboard, isn't color coded and doesn't have an optical port.
CPU: 6600K @ 4.6Ghz | COOLER: H100i GTX | MOBO: Asus Z170 AR | GPU: EVGA GTX 1080 Ti Hybrid | RAM: G.Skill Trident Z RGB 16GB |
CASE: Corsair 760T | PSU: Corsair RM750x | STORAGE: Samsung 850 EVO 250GB & Seagate 2TB | KEYBOARD: K70 RGB | MOUSE: Deathadder Elite
https://linustechtips.com/topic/264441-tritton-ax-pro-to-pc/#findComment-3596656
Have the same Headset, using the USB for the MIC and the Headset output for the Sound.
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
https://linustechtips.com/topic/264441-tritton-ax-pro-to-pc/#findComment-3596659
i do have a digital optical coming out of the amp
crap, just looked again and your motherboard does not have that. It's been a few years since I had that headset, it's not the pro+ is it? I think they are different
https://linustechtips.com/topic/264441-tritton-ax-pro-to-pc/#findComment-3596709
I would take to youtube for this one. I wouldn't know as I always used digital optical. That motherboard should be color coded but it's not. ew
https://linustechtips.com/topic/264441-tritton-ax-pro-to-pc/#findComment-3597037
i've searched for it but i cant seem to find anything on how to plug it in, that's why i was hoping that someone here could help xD
https://linustechtips.com/topic/264441-tritton-ax-pro-to-pc/#findComment-3597091
Sorry :( most people on here certainly won't have tritton's though. It's more of a console branded headset even though it works perfectly fine for pc too.
https://linustechtips.com/topic/264441-tritton-ax-pro-to-pc/#findComment-3597172
