What do you mean micro parts, do you mean mini itx
SYSTEM SPECS
i7 4790k | LTT Edition Noctua NH-U12S | Gigabyte Z97-SOC Force | 16GB Crucial Ballistix Tactical Tracer DDR3 | 120GB Samsung 850 EVO | 1TB Western Digital Caviar Blue | NVIDIA GTX 980ti | H440 Orange | EVGA 650B3 PSU
https://linustechtips.com/topic/264080-micro-parts/#findComment-3591747
same quality. just more time spent in the architect phase to fit everything into such a small form factor.
CM Storm Switch Tester MOD (In-Progress) - http://linustechtips.com/main/topic/409147-cm-storm-switch-tester-macro-mod/
       Ammo Can Speaker 02 (Completed) - http://linustechtips.com/main/topic/283826-ammo-can-speakers-02/       A/B Switch V 0.5 (Completed) - http://linustechtips.com/main/topic/362417-ab-switch-v0
     Build 01 - The Life of a Prodigy -  http://linustechtips.com/main/topic/13103-build-01-the-life-of-a-prodigy/             Build 02 - Silent Server 3000 - http://linustechtips.com/main/topic/116670-build-02-silent-server-3000/
https://linustechtips.com/topic/264080-micro-parts/#findComment-3591755
Basically, I'm wondering how micro parts are smaller and cheaper.  Do they have less power?  Are they just a lower quality?  Can they somehow do less then normal parts?  Are they lacking something? Etc.
I know that picture you're using! :D
Anywho, it fits in with the same price points that you would usually find. I don't  think they would be any more expensive or cheaper.
https://linustechtips.com/topic/264080-micro-parts/#findComment-3591761
Usually MicroATX motherboards have less PCIE lanes and less features - features that most people won't need anyways, so you aren't really missing out on much.
However, the main cost savings come from the fact that they need less materials to make the board, and shipping/etc etc is a lot cheaper, too.
Remember to be a good citizen and choose a 'best answer' when your problem has been resolved!
(that way people know when a problem's been resolved)
https://linustechtips.com/topic/264080-micro-parts/#findComment-3591807
microATX generally is just as good as ATX.
You get a few less expansion slots, but not much else changes.
CPU: AMD Athlon 5350 (2.66 Ghz OC) Motherboard: Asus AM1m-a Memory: Mushkin Radioactive 8GB DDR3-1600 GPU: MSI R7 260 1GD5 OC Storage: Toshiba Hybrid 500GB Case: Cougar Spike PSU: Rosewill Arc 450 OS: Deepin Linux 2014
https://linustechtips.com/topic/264080-micro-parts/#findComment-3591856
