Ok guys, im looking at building my first gaming rig because i'm done with console and want to join the "Glorious PC Master Race". So lets jump right in.
  • My budget is between $850 and $950 $US. (I'm working 30 hours a week putting myself through college, I'm poor)
  • I'm not looking for 500fps at ultra settings or even high. If i can play Battlefield 4, Borderlands 2, and/or Insurgency on medium and get 60-120fps I'm super.
  • I've never built a pc before but i am up to date on new tech and what the numbers mean, my only problem is knowing what innards will give me the performance i'm looking for. I've only ever dealt with high end PC's and low end PC's who would be better off functioning as single slot toasters.
  • Here is a link to the current build I'm considering   http://pcpartpicker.com/p/9Pbxt6
  • Keep it Intel and Nvidia if you would please.
  • I have my peripherals and insist on the CoolerMaster atx case I have put in the build linked above.
So yea, if you guys could help me in building my mid tier gaming rig i would greatly appreciate it.
Thanks!
https://linustechtips.com/topic/263545-first-gaming-build-need-some-help-please/
Do you really need 16gb of ram?
Cpu:
Intel i5 4460 Motherboard:Msi Z97S Sli krait Ram:HyperX Fury White (2x4) Storage:Seagate 1tb/Samsung 850 Evo 120gb Gpu:Gtx 960 2gb sc Case:S340 Black Psu:Corsair Rm 650w 80+ Gold certified
My anime list : http://myanimelist.net/animelist/KRImSIN
Thanks!
It has a couple issues for just gaming give me a minute and ill rework it for you
Well, If this is going to be a mid-tier gaming rig, you REALLY dont Need 16 gigz of RAM, other than that it is solid, just get at least a 128 gig SSD :)
Yea i do see your point with the ram, but im only going to use the ssd for boot and web browsers, 128 seems overkill since it will be running windows 8.1 and eventually 10.
That was just a thought :) I myself have a 120 gig SSD with just Windows and Diablo 3 + programs and ist 3/4 full :D
Motherboard: MSI Z97 PC MATE ATX LGA1150 Motherboard  ($99.95 @ Amazon)
Video Card: EVGA GeForce GTX 970 4GB ACX 2.0 Video Card  ($334.98 @ SuperBiiz)
Case: Cooler Master HAF XB EVO ATX Desktop Case  ($74.99 @ Micro Center)
Total: $962.51
Generated by PCPartPicker 2014-12-04 01:49 EST-0500
Here ya go redid a couple things the water cooler you had on there would not perform nearly as well as this air cooler and this cooler is cheaper. You also dont need 16 gigs of ram for gaming 8 is more than enough I also pulled off your ssd which made room for a GTX 970 which will give you ultra settings easy and wont need to be upgraded for a few years. You could always get a SSD at a later point unless you would rather give up the graphics performance for it.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($219.99 @ Amazon)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($28.99 @ Micro Center)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1866 Memory  ($80.97 @ OutletPC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($52.65 @ OutletPC)
Power Supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($69.99 @ NCIX US)
Total: $962.51
Good rig
"If Everton were playing at the bottom of the garden, I'd pull the curtains." - Bill Shankly
Total: $962.51
Wow, thanks! Do you think it would be worth it to run on my integrated graphics with minimal gaming and wait for the GTX 960 in the coming months to save some cash?
The cost of ram typically isn't that much I'd say. A lot of times I can find 8gb ram and find another from the same company that's within $50 extra and is 16gb. Not to mention even though games now at most require 8gb of ram, who can say for the future.
Thanks!
I'd still get at least a 120gb bro. 64gb brings would leave you barely any room. i have a 128gb ssd, and with win7 ultimate (i also eventually plan on going to Windows 10) and important things, i got about 60 left, it using up around 60 gigs. If i went with a 64 i'd have no room left.
Not really because it probably wont be as cost to performance effective as the 970 is and your first upgrade to this rig should be a 120gig or larger SSD when you can afford it and that should be the only thing you should have to do to this rig for at least 2 years. Plus the 960 will probably release at $275-300 so its not worth it for $50 savings.
Ok, so i took what you guys said into consideration and re-evaluated my first attempt at a build. http://pcpartpicker.com/p/6ZBWP6
I'm partial to windforce, but removing the ssd was a good idea. i can wait a while on it if i even ever get one.
What do you think about the 4690k? good choice? any recommendations?
The 4690K is one of the, if not the best CPU out for gaming right now in my opinion. Build looks good!
PC Specs:
CPU: i7-9700k  | Motherboard: Gigabyte Z390 Aorus Elite | RAM: 16GB's Team T-Force Vulcan 3000MHz | GPU: Zotac GTX 1070 8GB AMP! Edition  | Storage: 500GB WD Caviar Blue | 1TB WD Caviar Black | Crucial BX200 240GB SSD | OS: Windows 10 64-bit  | PSU: EVGA SuperNOVA G2 650W 80+ Gold | CPU Cooler: Noctua NH-D14 | Mouse: Logitech G502 Proteus Spectrum Headphones: Sennheiser HD 598 Special Edition's, HD 598 Cs | Keyboard: CM Storm QuickFire XT MX Blues Monitors: Acer GN246HL 144Hz, Acer G226HQLBbd 60Hz | Case: Phanteks Enthoo Pro.
