It depends on your definition of "best". Since motherboard bottlenecks aren't really a thing and the performance drop between the best performing and the least best performing ones is something like 3%, just get the one that you like or matches the colour scheme of your pc.
i7 4790K || R9 290X + R9 290 || 16GB G.Skill TridentX 1866 || Gigabyte Z97MX Gaming 5 || Crucial MX100 256GB || WD Caviar Blue 1TB
https://linustechtips.com/topic/263382-best-mob-for-800-pc/#findComment-3582803
Hi everybody! I need a new pc but I'm confused on which motherboard  to get. I do things like gaming, internet browsing, and light video editing. thanks!
what CPU are you planning to use and what form factor you need/want? also are you going to use more than one graphics card?
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/263382-best-mob-for-800-pc/#findComment-3582998
Im either going to do 680 quad sli or 970 sli. I would prefer to have low end intel. But it dosent matter really.
Higher end graphics with lower end CPU doesn't sound too balanced build for me.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/263382-best-mob-for-800-pc/#findComment-3585368
How on earth are you going to build a pc with gtx 970 sli on a $800 budget???
CPU: i7 4790k OC'd @ 4.6 ghz COOLER: Corsair H105 (SP 120mm Quiet Edition Fans) MOBO: ASRock Z97 Extreme 6 RAM: Kingston Hyper Fury 16GB (2x8) 1866mhz
SSD: Samsung 840 EVO 250GB HDD: WD Blue 1TB GPU: EVGA GTX 970 FTW 4GB PSU: EVGA Supernova G2 750w 80+ Gold Fully Modular CASE: Fractal Arc Midi R2
OPTICAL DRIVE: Samsung DVD Burner OS: Win 7 64bit   Please do some research of your own before asking questions. Google and Youtube are your friend.
https://linustechtips.com/topic/263382-best-mob-for-800-pc/#findComment-3586732
The motherboard should be a decision made considering what cpu you want, what size case you're working with, what your future plans are, etc. Not the other way around. And for the love of Peter Gabriel, don't go with quad 680s over a 970 sli (also, I want in on the black magic you're using to make all this happen for $800!)
That being said this might be a good starting place:
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor  ($168.99 @ NCIX US)
Motherboard: Asus Z97-A ATX LGA1150 Motherboard  ($119.99 @ Newegg)
Total: $288.98
Generated by PCPartPicker 2014-12-04 14:16 EST-0500
https://linustechtips.com/topic/263382-best-mob-for-800-pc/#findComment-3588028
If you want to build a $800 gaming PC. I'd suggest you go with the GTX 970. Since the power consumption on it is lower than the 680. Because if you went with the quad sli gtx 680 setup you'd need at least 1000W PSU to power up the whole thing. Which makes that out of your budget.
https://linustechtips.com/topic/263382-best-mob-for-800-pc/#findComment-3588157
http://pcpartpicker.com/p/tHXpNG Here for $825. You could do some changes, it's just an example
https://linustechtips.com/topic/263382-best-mob-for-800-pc/#findComment-3588310
I'd suggest this http://pcpartpicker.com/part/gigabyte-motherboard-ga970ad3p and an FX-6300 as CPU.
Yeah I took this and ran all the way to $800 with it. For $800, I think a single 970 is the absolute best you can do from a graphics standpoint, unless someone knows of a AMD GPU config (I admittedly know less about team red).
CPU: AMD FX-6300 3.5GHz 6-Core Processor  ($88.99 @ NCIX US)
Motherboard: Gigabyte GA-970A-UD3P ATX AM3+ Motherboard  ($74.98 @ OutletPC)
Video Card: Asus GeForce GTX 970 4GB STRIX Video Card  ($349.99 @ SuperBiiz)
Case: NZXT Source 210 (Black) ATX Mid Tower Case  ($32.99 @ Micro Center)
Total: $807.50
Generated by PCPartPicker 2014-12-04 14:42 EST-0500
https://linustechtips.com/topic/263382-best-mob-for-800-pc/#findComment-3588321
The cards are being handed down to me.
for such high end GPU's make sure you go with at least an haswell core i5...a core i5-4590 or i5-4460 with an H97 motherboard would be a perfect choice, if you are in the US these are good deals ATM:
CPU: Intel Core i5-4590 3.3GHz Quad-Core Processor ($188.99 @ NCIX US)
Motherboard: ASRock H97M PRO4 Micro ATX LGA1150 Motherboard ($74.99 @ Newegg)
Total: $263.98
Generated by PCPartPicker 2014-12-04 21:43 EST-0500
https://linustechtips.com/topic/263382-best-mob-for-800-pc/#findComment-3591077
Best mob?
I think there is a mistake where that b should have been a p, so best mop for $800?
:P
Motherboard: Asus Z87-A (NFC Express Edition) ATX LGA1150 Motherboard  ($84.99 @ Newegg)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1600 Memory  ($54.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($49.49 @ OutletPC)
Video Card: EVGA GeForce GTX 970 4GB ACX 2.0 Video Card  ($334.98 @ SuperBiiz)
Case: Corsair 200R ATX Mid Tower Case  ($39.99 @ Newegg)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply  ($34.99 @ Newegg)
Optical Drive: LG GH24NSC0B DVD/CD Writer  ($13.50 @ Newegg)
Total: $781.92
Generated by PCPartPicker 2014-12-04 23:37 EST-0500
The board used a older chipset Z87 instead of the Z97, but it does support SLI and you get a NFC express box.
With Z97
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard  ($109.99 @ Newegg)
Memory: Team Elite Plus 8GB (2 x 4GB) DDR3-1600 Memory  ($61.99 @ Newegg)
Total: $813.92
Generated by PCPartPicker 2014-12-04 23:44 EST-0500
https://linustechtips.com/topic/263382-best-mob-for-800-pc/#findComment-3591394
I am sooo stupid, i thought he wanted the best $800 mobo for a PC he is building....Facepalm...
 CPU: AMD FX-6300     COOLER: Hyper 212 EVO    MOBO: ASUS M5A97 R2.0    RAM: Team Vulcan 8Gb (4Gb x 2) , G-Skill Sniper (4Gb x 2)    PSU: Rosewill HIVE-750w    GPU: ASUS HD 7790 2Gb OC    CASE: NZXT Phantom 410    STORAGE: WD Black 1Tb , Intel 530 120Gb     AUDIO: HyperX Cloud , Sennheiser HD 518 , Audio Technica ATH-M30 , Sennheiser MM30G , Yamaha RX-V361 , Pioneer SP-BS22     PHONE: Samsung Galaxy S7 Edge     PERIPHERALS: Razer BlackWidow Ultimate Classic , Logitech g502 ( Thanks Syntaxvgm <3 )
https://linustechtips.com/topic/263382-best-mob-for-800-pc/#findComment-3591948
