hey guys i just bought a NZXT h440 in blue and black and as i picked it up i have took a bit of paint on the top, not alot but noticeable how would you hide it, maybe a permanent marker? any other ideas?
Check out my current projects: Selling site (Click Here)
If($reply == "for me to see"){
   $action = "Quote me!";
}else{
   $action = "Leave me alone!";
https://linustechtips.com/topic/262614-case-paint-chip/
Paint over it, or sharpie.
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
https://linustechtips.com/topic/262614-case-paint-chip/#findComment-3573236
Can you post a photo?
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/262614-case-paint-chip/#findComment-3573238
Photo please?
CPU: R5 5800X3D Motherboard - MSI X570 Gaming Plus RAM - 32GB Corsair DDR4 GPU - XFX 7900 XTX 4GB Case - NZXT H5 Flow (White) Storage - 2X 4TB Samsung 990 Pro PSU - Corsair RM100E Cooling - Corsair H100i Elite Capellix Keyboard Corsair K70 (Brown Switches)  Mouse - Corsair Nightsword RGB
https://linustechtips.com/topic/262614-case-paint-chip/#findComment-3573250
Photo please?
sorry for teh horrific quality a 50P coin for comparrison
}else{
https://linustechtips.com/topic/262614-case-paint-chip/#findComment-3573265
You should be able to Plasti-dip it to blend it back to the original color.
https://linustechtips.com/topic/262614-case-paint-chip/#findComment-3573280
You could either sharpie it. Or buy a can of rustoleom spray paint and put some on a Qtip and dab it on
Gaming Build:
Peripherals:
Laptop:
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/262614-case-paint-chip/#findComment-3573291
im not that bothered i might just perma mark it
}else{
https://linustechtips.com/topic/262614-case-paint-chip/#findComment-3573295
That also may work really well,
https://linustechtips.com/topic/262614-case-paint-chip/#findComment-3573298
yeah its not to bad just annoying when you just spent £90 on a case and within 4 hours of ownership a dent :P
}else{
https://linustechtips.com/topic/262614-case-paint-chip/#findComment-3573301
It could be worse. I was taking my H2 rig to a LAN and forgot to put thumb screws in the side panels. Got to the lan and parked in the garage, both side panels fell off and I had to bend the corners back to the way they originally were. It was really sad.
https://linustechtips.com/topic/262614-case-paint-chip/#findComment-3573311
yeah ikr its so annoying ill live with it its only a case i wont even see it because its on the side that will be against the wall
}else{
https://linustechtips.com/topic/262614-case-paint-chip/#findComment-3573327
