I just built a pc and I installed all the motherboard drivers but I still can't connect to the Internet. Any suggestions?
[-] i7 4790k @ 4.7ghz [-] Asus Maximus VII Formula [-] EVGA Gtx 980 Sc [-] Corsair H105 [-] Corsair Obsidian 750d [-]
https://pcpartpicker.com/user/TBNRunity/saved/#savedbuild_1797964
https://linustechtips.com/topic/262595-wifi-help/
i might sound like a retarded customer support person.
Does your motherboard have wifi? like does it have 2 antennas that screw into the motherboard IO?
if not, USB wifi sticks are like $20 for a pretty nice one and like $12 for a crap one. PCI-e 1x wifi cards are around $45
My Car: http://linustechtips.com/main/topic/274320-the-long-awaited-car-thread/?p=4442206
CPU: i5 4590 |Motherboard: ASRock H97M PRO4|Memory: Corsair Vengance 8gbs|Storage: WD Caviar Blue 1TB|GPU: ZOTAC GTX 760 2gb|PSU: Thermaltech TR2 500W|Monitors: LG24M35 24" & Dual 19"|Mouse:Razer DeathAdder 2013 with SteelSeries Qck mini|Keyboard: Ducky DK2087 Zero MX Red|Headset: HyperX Cloud|Cooling: Corsair 120mm blue LED, Lepa vortex 120mm, stock 120mm|Case:Enermax Ostrog Blue Windowed
https://linustechtips.com/topic/262595-wifi-help/#findComment-3573004
I paid $15 for my PCI-e wifi card about a month ago,
CPU: R5 5800X3D Motherboard - MSI X570 Gaming Plus RAM - 32GB Corsair DDR4 GPU - XFX 7900 XTX 4GB Case - NZXT H5 Flow (White) Storage - 2X 4TB Samsung 990 Pro PSU - Corsair RM100E Cooling - Corsair H100i Elite Capellix Keyboard Corsair K70 (Brown Switches)  Mouse - Corsair Nightsword RGB
https://linustechtips.com/topic/262595-wifi-help/#findComment-3573037
It has integrated wifi
https://linustechtips.com/topic/262595-wifi-help/#findComment-3573042
You say you installed motherboard drivers. Did you specifically install wireless drivers too? Some board manufacturers offer the download separate.
Yes, I installed all the drivers that came with the motherboard
Asus probe II
Intel chipset driver
Management engine interface
Intel LAN driver
Realtek audio driver
Asmedia sata controller driver
Asmedia USB 3.0 driver
Aprp utility
https://linustechtips.com/topic/262595-wifi-help/#findComment-3573218
I'm also using Windows 10, could that be the problem?
https://linustechtips.com/topic/262595-wifi-help/#findComment-3573240
Asus probe II
Intel LAN driver
Aprp utility
I dont see a wifi driver there. This http://dlcdnet.asus.com/pub/ASUS/misc/wireless/WIFI_Win7-8-8-1_VER6312231_6322231_6332231.zip is the wifi driver for your board
https://linustechtips.com/topic/262595-wifi-help/#findComment-3573308
