USB Storage Problem
Go to solution Solved by kameshss,
Virtual Disk Service error:
The cluster size is too big
Try to format it with HP USB Disk Format tool
Hi Everyone
So I have an USB, and i would like to make it my Windows Backup drive (for if i ever for any reason ruin my or a relatives Windows installation, i can reinstall off it), but the USB has some problems
So it's an 8 Gb usb, but it says that only 3.1Gb is avaible, even though nothing is on the drive. ( It's file system is Fat32.
https://linustechtips.com/topic/262466-usb-storage-problem/
Do a diskpart. Just be careful that you select the correct drive letter.
Open Command Prompt
Type "diskpart" (without quotes) then hit enter.
Type "list disk" (without quotes) and press enter to see a list of drives connected. Type "select disk=x" (without quotes). Replace "x" with the drive's disk letter. Hit enter.
Type "list partition" (without quotes) and press enter to see a list of the drive's paritions. Type "select partition=x" (without quotes) and press "Enter." ("X" is the partition you wish to select.)
Type "delete partition" (without quotes) and press enter to delete the partition that is currently selected. Once you have deleted it then type exit and hit enter.
https://linustechtips.com/topic/262466-usb-storage-problem/#findComment-3571469
Open Command Prompt
Is this right? http://puu.sh/de9QW/356c1532a9.png (wanna double check before i fuck something up)
https://linustechtips.com/topic/262466-usb-storage-problem/#findComment-3571493
Open Command Prompt
I did this and what do i need to do now?
https://linustechtips.com/topic/262466-usb-storage-problem/#findComment-3572567
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/262466-usb-storage-problem/#findComment-3572717
Thank you :D It worked :D
Awesome! :D
https://linustechtips.com/topic/262466-usb-storage-problem/#findComment-3572764
