Java help
Go to solution Solved by 79wjd,
Could you help me fix that error?
string input = scan.next();
char guessedLetter = input.charAt(0);
Hey guys. So my I'm working on a project with a partner. She wrote this code and asked me to take a look at it. When I try to compile it (this is a small portion of a bigger project) it highlights the bold text and says "unexpected type    required: variable; found: value" Can anyone tell me what's going on and how to fix it? I would really appreciate it. Oh and forget all of those brackets at the end there. They are from the earlier parts of the project.
public static void letterReplacement (String displayedWord)
        Scanner scan = new Scanner(System.in);
        StringBuilder displayedWord2 = new StringBuilder(displayedWord);
        int lengthOfDisplayedWord = displayedWord2.length();
        int lostGames;
        int guessesLeft = 5;
        int count = 0;
       if (guessesLeft == 0)
            lostGames++;
       else
        for(guessesLeft = 5; guessesLeft <= 0; guessesLeft--)
         for(count=0; count < lengthOfDisplayedWord; count ++)
            System.out.println(displayedWord);
            System.out.println("Guess a letter: ");
            String guessedLetter = scan.next();
            if (Character.isWhitespace(displayedWord2.charAt(count)))
            else
              if (Character.isLetter(displayedWord2.charAt(count)))
              else
                  if (displayedWord.charAt(count) = (guessedLetter))
                  else
https://linustechtips.com/topic/262106-java-help/
I reformatted the spacing to make it actually readable, and it doesn't do anything. Whats the code supposed to do? The line it fails on needs to be == not = since its a comparison not an assignment.
public static void letterReplacement (String displayedWord)    {        Scanner scan = new Scanner(System.in);        StringBuilder displayedWord2 = new StringBuilder(displayedWord);        int lengthOfDisplayedWord = displayedWord2.length();        int lostGames;        int guessesLeft = 5;        int count = 0;       if (guessesLeft == 0)       {            lostGames++;       }       else       {            for(guessesLeft = 5; guessesLeft <= 0; guessesLeft--)            {                  for(count=0; count < lengthOfDisplayedWord; count ++)                   {                        System.out.println(displayedWord);                        System.out.println("Guess a letter: ");                       String guessedLetter = scan.next();                         if (Character.isWhitespace(displayedWord2.charAt(count)))                         {                         //does nothing                          }                          else                          {                                   if (Character.isLetter(displayedWord2.charAt(count)))                                  {                                    //does nothing                                   }                                    else                                   {                                            if (displayedWord.charAt(count) == (guessedLetter))                                            {                                              //does nothing                                             }                                             else                                             {                                                     //does nothing                                             }                                     }            }         }        }       }    }
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/262106-java-help/#findComment-3568260
I reformatted the spacing to make it actually readable, and it doesn't do anything. Whats the code supposed to do, and does it tell you what line it fails on?
public static void letterReplacement (String displayedWord)    {        Scanner scan = new Scanner(System.in);        StringBuilder displayedWord2 = new StringBuilder(displayedWord);        int lengthOfDisplayedWord = displayedWord2.length();        int lostGames;        int guessesLeft = 5;        int count = 0;       if (guessesLeft == 0)       {            lostGames++;       }       else       {            for(guessesLeft = 5; guessesLeft <= 0; guessesLeft--)            {                  for(count=0; count < lengthOfDisplayedWord; count ++)                   {                        System.out.println(displayedWord);                        System.out.println("Guess a letter: ");                       String guessedLetter = scan.next();                         if (Character.isWhitespace(displayedWord2.charAt(count)))                         {                         //does nothing                          }                          else                          {                                   if (Character.isLetter(displayedWord2.charAt(count)))                                  {                                                    }                                    else                                   {                                            if (displayedWord.charAt(count) = (guessedLetter))                                            {        }                                             else                                             {        }                                     }            }         }        }       }    }
Sorry about that, I blame it on BlueJ (my teacher wants us using that) And it fails on the very last if statement. Oh and it plays the game hangman. So it has a dictionary to 20 words and displays spaces, then the user has 6 guesses to get the word. The user guesses letters and the program replaces the spaces with the letters if they are correct.
https://linustechtips.com/topic/262106-java-help/#findComment-3568279
Also, the for loop condition should be > 0, not <= 0.
PSU Tier List | CoC
https://linustechtips.com/topic/262106-java-help/#findComment-3568287
Do you want me to give you the entire code so you can see? It's incomplete but you can at least read it.
https://linustechtips.com/topic/262106-java-help/#findComment-3568318
Sorry about the spacing. I think it's my editor.
* This class contains the main driver of the game
* Name: Nick Marino and Jessie Slater
* Date: 11-24-14
import java.util.Random;
import java.util.Scanner;
public class HangMan
    private static int wordChoice;
    private static String displayedWord;
    public static String pickWord(int wordChoice)
        switch(wordChoice)
            case 0:
                displayedWord = "motherboard";
            case 1:
                displayedWord = "case";
            case 2:
                displayedWord = "powersupply";
            case 3:
                displayedWord = "harddrive";
            case 4:
                displayedWord = "mouse";
            case 5:
                displayedWord = "keyboard";
            case 6:
                displayedWord = "monitor";
            case 7:
                displayedWord = "graphicscard";
            case 8:
                displayedWord = "processor";
            case 9:
                displayedWord = "latency";
            case 10:
                displayedWord = "ping";
            case 11:
                displayedWord = "gaming";
            case 12:
                displayedWord = "resolution";
            case 13:
                displayedWord = "watercooling";
            case 14:
                displayedWord = "cache";
            case 15:
                displayedWord = "memory";
            case 16:
                displayedWord = "chipset";
            case 17:
                displayedWord = "intel";
            case 18:
                displayedWord = "notebook";
            case 19:
                displayedWord = "desktop";
            case 20:
                displayedWord = "aliasing";
        return displayedWord;
    public static void main(String[]args)
            String userChoice;
            int gameCount = 0;
            int lostGames = 0;
            System.out.print("Welcome to a game of hangman!");
            System.out.print("Do you want to play? (Y/N): ");
            userChoice = scan.next();
            while (!userChoice.equalsIgnoreCase("n"))
                  switch (userChoice)
                       case "Y":
                       case "y":
                           Random wordPick = new Random();
                           System.out.print(pickWord(wordPick.nextInt()));
                           letterReplacement(displayedWord);
                           break;
                       default:
                           System.out.println("Bad input.");
                           break;
                  gameCount++;
                  System.out.println("You have played " + gameCount + " games. Do you want to play again?");
        int lostGames;
        int count = 0;
            lostGames++;
       else
            else
              else
                  else
https://linustechtips.com/topic/262106-java-help/#findComment-3568331
I'm just pointing out that the code you listed doesnt actually do anything other than deitterate 'guessesleft' and print a couple lines (the conditionals are all empty).
But if you change the = to an == it should work (or at least compile).
PSU Tier List | CoC
https://linustechtips.com/topic/262106-java-help/#findComment-3568335
Yes I know, I said that it was part of a bigger project. But it says at that very last if statement  "unexpected type    required: variable; found: value" and it highlights the word "count"
https://linustechtips.com/topic/262106-java-help/#findComment-3568352
shouldn't you be using displayedWord2.charAt(count) not displayedWord.charAt(count).
You should also change guessedLetter to type char instead of string.
PSU Tier List | CoC
https://linustechtips.com/topic/262106-java-help/#findComment-3568366
shouldn't you be using displayedWord2.charAt(count).
You should also change guessed letter to type char instead of string.
Even when I change that it still has the same error. == doesn't work either. Can you put it through your editor and see for yourself?
https://linustechtips.com/topic/262106-java-help/#findComment-3568378
Did you change guessedLetter to type char
PSU Tier List | CoC
https://linustechtips.com/topic/262106-java-help/#findComment-3568417
How exactly do I do that? I was just trying to....
just do:
char guessedLetter = //scanner;
I'm pretty sure you can use a scanner for a char the same was as a string.
PSU Tier List | CoC
https://linustechtips.com/topic/262106-java-help/#findComment-3568450
just do:
char guessedLetter = scan.next();
How do you scan in a character though? When I compile this, it highlights the () and says that string cannot be converted to char.
https://linustechtips.com/topic/262106-java-help/#findComment-3568470
I also get the error
Variable 'lostGames' might not have been initialized
// ...int lostGames; // not initializedint guessesLeft = 5;int count = 0;if (guessesLeft == 0){    lostGames++; // but trying to increment it}// ...
I'm still getting the original error
        int lostGames;
        int count = 0;
            lostGames++;
       else
            else
              else
                  else
I'm still getting the original error.
https://linustechtips.com/topic/262106-java-help/#findComment-3568531
PSU Tier List | CoC
https://linustechtips.com/topic/262106-java-help/#findComment-3568613
