no words just go...(for all of us)
2-1/x = 4/3x
what does x equal?
here is  another one (sorry)
y+1/4y - 5/6y = 1/2
thanks
Do not take life too seriously. You will never get out of it alive.
        :o
https://linustechtips.com/topic/261425-maths-help/
Is it 2-(1/x) or 2(-1/x) or (2-1)/x?
ill put pictures...
        :o
https://linustechtips.com/topic/261425-maths-help/#findComment-3561252
-snip-
post-163060-0-20959200-1417419264_thumb.
Also head over to our thread dedicated to maths.
http://linustechtips.com/main/topic/260951-post-your-maths-problems-here/
Lorem ipsum dolor sit amet, consectetur adipiscing elit. Quisque euismod suscipit est, non placerat turpis vestibulum sed. Phasellus et faucibus odio. Donec a nisi at purus porttitor ullamcorper auctor a nibh. Integer id neque a nisi laoreet ultrices id ac augue. Nulla facilisi. Nullam purus elit, dictum quis euismod vitae, mollis non dui. Morbi vehicula neque eu mattis bibendum. Curabitur sed odio tortor. Sed euismod mi in diam volutpat, vitae convallis ipsum mattis. Praesent eleifend faucibus pulvinar. Interdum et malesuada fames ac ante ipsum primis in faucibus. Vestibulum velit nunc, fermentum a libero a, venenatis tempus lectus.
https://linustechtips.com/topic/261425-maths-help/#findComment-3561258
thanks and cool, will be there alot i guess. haha
        :o
https://linustechtips.com/topic/261425-maths-help/#findComment-3561277
Also seeing the picture now the solution is actually wrong, just misread it from the typing (use brackets plz! they save lives)
https://linustechtips.com/topic/261425-maths-help/#findComment-3561283
2-1/x = 3/3x
what does x equal?
y+1/4y - 5/6y = 1/2
thanks
ijust saw that you used 3 instead of 4 on the first. noprob
        :o
https://linustechtips.com/topic/261425-maths-help/#findComment-3561286
Usually with multiple fractions that have pronumerals you want to combine them into one term so that way you can start multiplying the denominator to the other side or do things like cross multiply.
https://linustechtips.com/topic/261425-maths-help/#findComment-3561297
i know it kind rude but ca yu do it again with correct umbers?  thanks
        :o
https://linustechtips.com/topic/261425-maths-help/#findComment-3561327
got x=7/6 and y=-7/3
https://linustechtips.com/topic/261425-maths-help/#findComment-3561447
just quit this shit. getting 2's everytime...
what do ya mean?
        :o
https://linustechtips.com/topic/261425-maths-help/#findComment-3561963
