CPU and MB upgrade
Go to solution Solved by JoaoPRSousa,
I would say put the new components in, plug everything and do the OS install.
I am upgrading my motherboard and processor (amd to intel) and am planing a fresh install of Windows 8.
All my important data is on my second drive. Should I just throw in the new hardware and go from there? Or is there a way to remove everything from the drive with the OS on it? Basically my question is, what is the best way to go about upgrading?
Recent games -- LoL, FO4, TESV, XCOM 2, Life is Strange, Overwatch, Ark, Total War Attila, Hearthstone.  <(^^,)>
https://linustechtips.com/topic/261225-cpu-and-mb-upgrade/
