I'm new to the android world so I don't know a whole lot of what I'm doing.
Today I updated the Nvidia Shield Tablet to android 5.0 and I ended up loosing my Nvidia skin/interface. It now looks terrible all white and harder to use.
Was it suppose to remove the old skin or did I do something wrong?
How do I fix this?
https://linustechtips.com/topic/261122-shield-update-50-problem/
How do I fix this?
Nvidia had a skin? I thought it was stock Android.?
Nonononono.
The Shield (Portable and Tablet) devices ran pretty much as close to stock Android as you could get, just with the necessary applications added.
Android 5.0 (Lollipop) has a revised UI, with a focus on material design.
Sig under construction.
https://linustechtips.com/topic/261122-shield-update-50-problem/#findComment-3557880
