Could i run xfire 7850 in my system (in profile) with my PSU?
https://linustechtips.com/topic/261070-crossfire-hd7850-power/
It would be pushing it. I wouldn't.
i mean, its a good PSU, and i can get a second hd 7850 for cheap
https://linustechtips.com/topic/261070-crossfire-hd7850-power/#findComment-3557328
Yes.
My 7870 never exceeded 150W (just GPU) and that requries more
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/261070-crossfire-hd7850-power/#findComment-3557352
The HD7850 has a very modest power draw. http://www.techpowerup.com/reviews/Powercolor/HD_7850_PCS_Plus/26.html
Using a ~$2000 equipment, TPU was able to isolate the power draw of the 7850 to have a power draw of 120wDC during Furmark. A quality 550w indeed is able to power two of them in CFX.
https://linustechtips.com/topic/261070-crossfire-hd7850-power/#findComment-3557387
Yes, but it is still "only" a 550W. 2 7850s OCd (i assume you'll be OCing) would draw ~ 175W (x2) = ~350W + CPU (oc'd a tad bcuz otherwise you may get a potential bottleneck) (120 W + other stuff (30W)) = 500W
You can, but it will put more strain on the PSU = more noise AND most likely shorter lifespan.
Oh, and don't forget PSUs degrade which means that it will not be able to output 550W forever.
Samung Tab S 8.4
https://linustechtips.com/topic/261070-crossfire-hd7850-power/#findComment-3557398
No oc on my mb, so 350+100= 450 leaves 100w for stuff and degrading
https://linustechtips.com/topic/261070-crossfire-hd7850-power/#findComment-3557413
OK, also would it be worth gettings a second 7850 for 40 USD?
https://linustechtips.com/topic/261070-crossfire-hd7850-power/#findComment-3557444
WHERE IS THIS 7850 FOR $40?!!?!?
Eric S. Raymond used an E6600 from 2005 until 12/30/14 or open source software creation. Raw data computations in excess of 18GB each. Core 2 Duos still have tons of life left, my friend.
https://linustechtips.com/topic/261070-crossfire-hd7850-power/#findComment-3557473
Craigslist
https://linustechtips.com/topic/261070-crossfire-hd7850-power/#findComment-3557550
Generally speaking, a quality PSU will have some engineering overhead accounted for when providing its power rating. Some of which significantly higher than others. As such a quality PSU like the XFX TS Gold (Seasonic S12G) would at least outlive it's warranty period if you were to run it 24/7 near it's rated output.
Of course, I'm not suggesting you do this, and you won't be. The components in your system will not be running at 100% load simultaneously. During gaming load it will be <~350w DC.
https://linustechtips.com/topic/261070-crossfire-hd7850-power/#findComment-3557561
He lives in a risky part of the city, we can meet him in a public place, but it could be stolen. What do you think?
https://linustechtips.com/topic/261070-crossfire-hd7850-power/#findComment-3557690
risk of it stolen? little to none. no one steals just components of PCs unless its public schools, and i doubt they are running 7850s. your probably fine.
https://linustechtips.com/topic/261070-crossfire-hd7850-power/#findComment-3558080
My parents won't let me due to risk
https://linustechtips.com/topic/261070-crossfire-hd7850-power/#findComment-3558134
