Hello folks
Im building a new rig and i want to ask a few things especially about the RAM section.
This is my build: http://pcpartpicker.com/p/hHHWP6
Now,im going with this motherboard mostly for aesthetics and beside that i have options for the future if im planning to overclock.
Ive searched a lot and as far as i understand the standard CL/Mhz is 9/1600 on a RAM when it comes to gaming(thats my purpose too).
With this motherboard though i have plenty of choices speed-wise when it comes to RAM.
Should i go for these RAMs i chose(which they apparently match my theme build) or spent more money for higher speed ones and will i notice a difference in the performance of my gaming?
Is it worh it?
If yes which ones do you recommend and what CL/Mhz?
if no should i buy a cheaper mobo?Any suggestions?
And finally should i consider overclocking?
Thanks in advance! :)
https://linustechtips.com/topic/260786-many-many-questions/
Go with matching the colors, you will not benefit from extra CAS or Mhz, gains are very minimal.
If you have the money and want a bit of a little extra fps (1 - 4 max) get lower CAS it higher Mhz
I never overclock, and dont really know how .. if you do know how to overclock make sure you have a good cooler like Corsairs H100i
Asus ROG mobos are a bit expensive, youll find good MSI motherboards for a cheaper price. Both are good companies
"If Everton were playing at the bottom of the garden, I'd pull the curtains." - Bill Shankly
https://linustechtips.com/topic/260786-many-many-questions/#findComment-3554189
Higher speed RAM doesn't matter in gaming unless you're using an APU or it's BF4.
And I would recommend 16GB of RAM.
You know why?
When I look in build threads I see a lot of people saying "you only need 8GB of RAM for gaming!"
Heck, I've even said it a couple times.
But I go look at my RAM usage every day, and it's always above 8 GB with no games/intensive programs running. Always.
That's personal choice though. If you're tidy about closing programs you don't need or whether you tend to leave them open like I do (especially if I'm modding skyrim or something).
EDIT: If you're going with 2 970's and a 4790k it seems unbalanced to only get 8GB of RAM. I typed the info above when I couldn't see the build because it took the page a while to load :P
Someone told Luke and Linus at CES 2017 to "Unban the legend known as Jerakl" and that's about all I've got going for me. (It didn't work)
https://linustechtips.com/topic/260786-many-many-questions/#findComment-3554230
you wont see any noticable difference in ram sppeds or cas latency
CPU: i7 4790k OC'd @ 4.6 ghz COOLER: Corsair H105 (SP 120mm Quiet Edition Fans) MOBO: ASRock Z97 Extreme 6 RAM: Kingston Hyper Fury 16GB (2x8) 1866mhz
SSD: Samsung 840 EVO 250GB HDD: WD Blue 1TB GPU: EVGA GTX 970 FTW 4GB PSU: EVGA Supernova G2 750w 80+ Gold Fully Modular CASE: Fractal Arc Midi R2
OPTICAL DRIVE: Samsung DVD Burner OS: Win 7 64bit   Please do some research of your own before asking questions. Google and Youtube are your friend.
https://linustechtips.com/topic/260786-many-many-questions/#findComment-3554239
You know why?
About the 2 970's...my bad
Im going with one atm but im planning to add a second one in the future when i can afford it.
Thats why im going for 8 GB of RAM for now and also upgrade to 16GB in the future
Is 4x4 good choice or should i go with 2x8 RAMs?
https://linustechtips.com/topic/260786-many-many-questions/#findComment-3554284
2x8gb hands down
The BBQ: i7-4770 / 212x / Tri-X R9 290x 1075/1400 / MSI H87-G43 GAMING / EVGA G2 850W / Corsair Spec 03 / Samsung 840 EVO 250gb SSD / Toshiba 2TB HDD / 8gb Kingston DDR3 1600mhz
Peripherals: G710+ / G502 / Bose Companion 2 Series III / Audio Technica ATH-M40x / Sound Magic E50
Monitors: Dell U2414H
https://linustechtips.com/topic/260786-many-many-questions/#findComment-3554302
