What did you install when you installed Avast? In other words, did you do a custom installation or express?
https://linustechtips.com/topic/260168-avast-help/#findComment-3547703
Avast... its pretty unstable.  With the recent Windows Update Avast caused BSODs.  And now this.  Is it an error like an actual error? Or does the page say the page transmission is insecure, if thats the case its a matter of installing the Avast certificate.
But yeah, just try install the Avast digital certificate into chrome.
https://linustechtips.com/topic/260168-avast-help/#findComment-3553462
What windows are you using? if youre using windows 8.1 uninstall avast immediately.
They still dont know any solution on why avast is not working properly with win 8.1
"If Everton were playing at the bottom of the garden, I'd pull the curtains." - Bill Shankly
https://linustechtips.com/topic/260168-avast-help/#findComment-3553466
It'd be nice if this person would come back to their thread.
https://linustechtips.com/topic/260168-avast-help/#findComment-3553634
