Before Christmas I need a $1000 mini ITX build with the following...
Core i5 or i7 "k" series
Overclockable ITX board
Sealed water Cooling loop
8-16GB DDR3-1866 or higher
2TB HDD
256GB SSD
GTX 970
Good PSU
Optical Drive
AfterMarket Thermal Paste
Can only go up to $50 off budget
Smallest case possible (no pridogy's)
I tried everything on pcpartpicker but I cant find a combination... Anyone help?
https://linustechtips.com/topic/259410-itx-building-help/
2TB HDD
256GB SSD
GTX 970
Good PSU
Optical Drive
With all of your requirements you'd be hard pressed to get all of that for $1,000 or less. You might have figured out what you can forgo to keep the build under your $1,000 budget, because I don't think you can get all of that for $1,000. I'd be happy to be wrong for your sake.
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
https://linustechtips.com/topic/259410-itx-building-help/#findComment-3540594
Hey OP, heres a somewhat $1000 build (you can cut some more corners to save if you want)
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($207.27 @ TigerDirect)
CPU Cooler: NZXT Kraken X31 69.5 CFM Liquid CPU Cooler  ($59.99 @ NZXT)
Motherboard: Gigabyte GA-Z97N-WIFI Mini ITX LGA1150 Motherboard  ($102.98 @ SuperBiiz)
Memory: Kingston Savage 8GB (1 x 8GB) DDR3-1866 Memory  ($88.99 @ Directron)
Storage: Crucial MX100 256GB 2.5" Solid State Drive  ($98.98 @ SuperBiiz)
Video Card: EVGA GeForce GTX 970 4GB ACX 2.0 Video Card  ($319.98 @ SuperBiiz)
Optical Drive: Asus BW-12B1ST/BLK/G/AS Blu-Ray/DVD/CD Writer  ($29.99 @ Newegg)
Total: $1066.15
Generated by PCPartPicker 2014-11-28 10:14 EST-0500
No paste since I am not an expert on such a matter.
Desktop: i7-4790k, Samsung 840 EVO 250GB, Seagate Barracuda 3TB, 2xR9 290 Vapor-X's (1 working atm), Asus Z97-Pro, NZXT H440 White, 16GB G. Skill Sniper RAM, NZXT HALE V90 850W.
Laptop: Samsung Chromebook 11.6"
Phone: 8GB Galaxy S4
https://linustechtips.com/topic/259410-itx-building-help/#findComment-3540659
That's kinda my point though, he can't get all he's wanting for $1,000 or less. Corners are going to have to be cut. ;)
@Hyttech
https://linustechtips.com/topic/259410-itx-building-help/#findComment-3540677
Left about $100 for whatever case  & thermal paste you want
CPU Cooler: Corsair H90 94.0 CFM Liquid CPU Cooler  ($49.99 @ Newegg)
Video Card: Gigabyte GeForce GTX 970 4GB Video Card  ($329.90 @ Newegg)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($19.99 @ Newegg)
Total: $943.08
Generated by PCPartPicker 2014-11-28 10:19 EST-0500
RIP in pepperonis m8s
https://linustechtips.com/topic/259410-itx-building-help/#findComment-3540682
@Hyttech
Yeah I guess that is true, unless OP is banking on there being a massive sale before Christmas
https://linustechtips.com/topic/259410-itx-building-help/#findComment-3540702
Haha yeah, well good luck with that. ;)
https://linustechtips.com/topic/259410-itx-building-help/#findComment-3540735
yeah going to be to tight of a budget for the hardware your after
only cases i can think of not prodigy , would be Corsair Graphite 380T , Obsidian 250D or SilverStone Raven RVZ01 possible a EVGA Hadron Hydro and they wont be cheap on top the other parts
half the budget is going into the graphics card at the minium
https://linustechtips.com/topic/259410-itx-building-help/#findComment-3540739
