I modded my Watchdogs but seems like I can't start it.I installed sweetfx and many other mods and an error keeps popping up about an entry point not being found.
Currently running windows 8.
Corsair 760T White | Asus X99 Deluxe | Intel i7-5930k @ 4.4ghz | Corsair H110 | G.Skill Ripjawz 2400mhz | Gigabyte GTX 970 Windforce G1 Gaming (1584mhz/8000mhz) | Corsair AX 760w | Samsung 850 pro | WD Black 1TB | IceModz Sleeved Cables | IceModz RGB LED pack
https://linustechtips.com/topic/259205-watchdogs-mod-problem/
Did you install Directx11 in your PC? But knowing that you are running on 8, i suspect its preinstalled. Anyways, does the game run before you installed the mod?
Developer by day, Gamer by night
CPU - Intel i7 4770k | MOBO MSI G45 Gaming | RAM - G.Skill RipJaws X 1600mhz 4x4gb CL7 | CASE - NZXT H440 | GPU - MSI R9 290 | PSU - Corsair RM850 | SSD - Samsung 840 EVO 128gb | HDD - Western Digital Black 2TB
https://linustechtips.com/topic/259205-watchdogs-mod-problem/#findComment-3538717
Removed the sweetFx and the game is running fine. I was looking for a solution to run sweetfx on windows 8.
https://linustechtips.com/topic/259205-watchdogs-mod-problem/#findComment-3538730
I THINK there's a separate sweetfx version for 8.1 or something that fixes this...if I remember right..I think I had this problem with bf4
Been looking for like past 20 minutes. :(
https://linustechtips.com/topic/259205-watchdogs-mod-problem/#findComment-3538752
Maybe this will help?
http://forums.guru3d.com/showthread.php?t=390465
Win 8.1 uses dx11.2 vs 11.1 and that's the difference, and the sweetfx creator doesn't use 8.1, and said "fuck it" or something
https://linustechtips.com/topic/259205-watchdogs-mod-problem/#findComment-3538769
I just found one that was made by the creators. Does SweetFX config still works?
https://linustechtips.com/topic/259205-watchdogs-mod-problem/#findComment-3538802
