AMD CPU and APU Help
Solved by EarthboundHero,
If you're just gaming the 860K will be better, lower power consumption, cheaper boards, better OC's, and newer platform. Though it has less cores, so if you're streaming, video editing or anything like that go for the 8320.
l3eyond ·
1
Serendipity1344 ·
Posted in Graphics Cards4 -
1
1
5
1
toxic_worper ·
Posted in New Builds and Planning9
