So my GTX 670 was as far as I know up until this day boosting perfectly fine.
I have a meager 50 mhz overclock which gets the clock up to 1250-1300 during FurMark but for some reason in both Planetside 2 and Batman Arkham Asylum my card has not been boosting at all. It goes up all the way to the base clock of 1019 and 1011 mV. My fan speed is at auto and my card is currently at 46 degrees in the middle of playing Batman Arkham Asylum.
The only thing that really makes it boost to its full potential is FurMark which goes to as I said earlier my boost of 1250-1300 mhz.
I don't really know what's up. I'm going to test Far Cry 3 and Trine 2 in a bit.
If anyone can help it would be much appreciated. I tried rebooting a few times to no avail.
If it means anything my 3570k is overclocked to 4.5 Ghz at 1.185 volts.
GPU is a GTX 670 power edition by MSI.
Corsair 5000D / Intel Core i7-12700KF / Arctic Liquid Freezer 3 360mm / MSI Meg Z690 Ace / RTX 3080 Ti Founder's Edition / 64GB Corsair Vengeance RGB 3200 MHz CL32 / Corsair RM1000X / 1TB ADATA SX8200 Pro (Boot) / 2TB Acer Predator GM7000 Gen 4 (Storage) / MSI MPG271QRX-QD / MSI Mag 274QRF-QD / LG CX 55" / G-Pro Wireless
https://linustechtips.com/topic/25855-gtx-670-not-boosting/
have you checked your frame rate target. maybe you accidentally set it to something low like 40fps and since furmark is heavily gpu taxing it would be the only thing that wont be reaching 40 fps so it uses all your gpu strength and since the games probably dont need that much of the gpu at something like 40fps thats why it might not be boosting. Its worth a check.
https://linustechtips.com/topic/25855-gtx-670-not-boosting/#findComment-328430
Yeah I thought it was that but I checked multiple times.
I can confirm that right now in Far Cry I'm at 1283 MHz. I don't understand why it does this. -_-
Also Trine 2 wont boost either. Ugh
https://linustechtips.com/topic/25855-gtx-670-not-boosting/#findComment-328435
Maybe you've got vsync enabled in those certain games. I dont know how/if it affects the boost but it may be worth looking for :P
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/25855-gtx-670-not-boosting/#findComment-328535
Sadly I've checked that as well, to no avail.
At least I know I'll be able to play Far Cry at the highest possible FPS.  :mellow:
https://linustechtips.com/topic/25855-gtx-670-not-boosting/#findComment-328547
Dude is your adaptive v-sync on or off? that is a driver setting not in game, that is what happens when i play most of the games with this card, it even underclocks to like 810 mhz on the core, but in crysis i get 1110 boost or sometimes in unigine 1123, and btw how many fps do you get in batman, and do you play Planetside with max settings?
System
CPU: i7 4770kMotherboard: Asus Maximus VI HeroRAM: HyperX KHX318C9SRK4/32 - 32GB DDR3-1866 CL9 / GPU: Gainward Geforce GTX 670 Phantom Case: Cooler Master HAF XBStorage: 1 TB WD BluePSU: Cooler Master V-650sDisplay(s): Dell U2312HM, LG194WT, LG E1941
Cooling: Noctua NH-D15Keyboard: Logitech G710+Mouse: Logitech G502 Proteus SpectrumSound: Focusrite 2i4 - USB DAC / OS: Windows 7 (still holding on XD)
https://linustechtips.com/topic/25855-gtx-670-not-boosting/#findComment-329943
