Hi.. I'm using a quad core system with 4.5 GB of DDR2 for playing COD 4 multyplayer. I had a HD 5670 card.but few days ago it didint work.So i bought used nvidia GT 9600 512 mb card.But I get only 128 mbs in system properties.(showing 512 mb in bios) :o And i saw now.It shows 8500 GT.
https://linustechtips.com/topic/257779-gt-9600-help/
use GPU-Z ID
it will show the actual GPU model
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/257779-gt-9600-help/#findComment-3524739
