So I Love dell XPS desktops, I personally have a 630i, and my fiancé has an XPS 700, she is more than happy with the 700 but I want something more, im keeping the case! im looking at putting in a new gigabyte H97 gaming 3 motherboard with a gtx 590, im not sure what cpu to put in but im going with 8-16 GB ram im going for the corsair dominator platinum, if you have any suggestions let me know I can change any part of this pc besides the case, its in perfect condition and I wont part with it.
EDIT: if your wondering why a GTX 590, its because I already have one from an old system.
https://linustechtips.com/topic/256905-system-upgrade-help/
should I keep the 590? I have no idea if its a good card or not, I could get a 760 if its better.
590 is old and I would definetly upgrade it if you are a gamer.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/256905-system-upgrade-help/#findComment-3516511
Get a 4430/4440/4460 i5, and also you really don't need dominator platinum. Cheaper ram would perform exactly the same
This is a great suggestion
The GTX590 packs two GTX580GPU's and packs more punch than a GTX760 it's still a good card for 1080p gaming even though you might have to turn down some texture settings and use a lesser anti-aliasing due to the VRAM capping out.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/256905-system-upgrade-help/#findComment-3516891
I'd take a 590 over the 760...if anything you should be considering a gtx 970 or R9 290. The 590 is no slouch, and even if you didn't want to keep it sell it on Ebay for ~$170-250.
LanSyndicate Build | i5-6600k | ASRock OC Formula | G.Skill 3600MHz | Samsung 850 Evo | MSI R9-290X 8GB Alphacool Block | Enthoo Pro M | XTR Pro 750w | Custom Loop |
Daily | 5960X | X99 Sabertooth | G.Skill 3000MHz | 750 NVMe | 850 Evo | x2 WD Se 2TB | x2 Seagate 3TB | Sapphire R9-290X 8GB | Enthoo Primo | EVGA 1000G2 | Custom Loop |
Game Box | 4690K | Z97i-Plus | G.Skill 2400MHz | x2 840 Evo | GTX 970 shorty | Corsair 250D modded with H105 | EVGA 650w B2 |
https://linustechtips.com/topic/256905-system-upgrade-help/#findComment-3516936
